06 Six Speed Tranny Question - JeepForum.com
post #1 of 26 Old 10-03-2006, 06:31 PM Thread Starter
Nick B
Are there any issues with this tranny. Is it as reliable and strong as the old 5 speed ? Smooth shifter ?
Nick B is offline
post #2 of 26 Old 10-03-2006, 06:35 PM
Rocky529
Rocky529's Avatar
I have the 5 speed, and heard the 6 speed is great. I heard that it is notchy going into 2nd at times... it sounds like there is a few more pet peeves about it over the 5 speed. I'll let a 6 speed owner chime in, as I am only going off what other people posted.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 26 Old 10-03-2006, 06:39 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
Other than that notciness going into second (as was posted above), I've had no problems. I'm on 33s with 3.07 gearing and its doing pretty good. I've got no complaints...other than that notch into 2nd. If you shift it right, though, it goes away. You just need to give it a little lovin'.
rjt36 is offline
post #4 of 26 Old 10-03-2006, 06:51 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
2nd is notchy here too... has been since I got it but it's never been a problem. It is worse in the winter, but it goes away once everything is warmed up.
I'll be Savvy someday!
neZZr is offline
post #5 of 26 Old 10-03-2006, 06:53 PM
jeep rio
Before I totaled mine I had a 4.0 with 4.10's and the six speed sitting on 33's and that baby worked Great. The clutch was alot lighter on it than my old jeeps 5 speed was which meant less sore of a calf while wheelin lol! I would have got another sixspeed but I went with an auto this time cause I couldnt beat the Price I got it for!
1997 XJ Sport 2 Door- High country suspension and skid plate package.
2006 TJ- Custom lift 4in Full traction springs, OME shocks, Kilby skid plates and bumper, Full traction 3 link in rear, JKS control arms upper lower, Banks exhaust, Edge trail jammer, 4.56's and true trac front, Eaton elocker rear. D30, D44
1995 YJ Rio Grande- 4.0l Swap 3.5 in 4wd hardware lift, Ford 8.8 Rear 4.10 gears.
jeep rio is offline
post #6 of 26 Old 10-03-2006, 07:01 PM
GeoBigJon
Cactus Hobbit
GeoBigJon's Avatar
2014 JK Wrangler
I have it and have had no issues with the tranny. I have grinded reverse a couple times when I got in a hurry, from 5th to 6th. I have heard it said before from someone, you have to shift it like its a tractor sometimes I can see this, but when you want to get her up and go, I haven't had any problems.
2014 JK Anvil Rubicon
If you eat, drink, or wear cloths then you're involved in agriculture.
GeoBigJon is offline
post #7 of 26 Old 10-03-2006, 07:01 PM
azcoyote
azcoyote's Avatar
I would rate the shifting as OK and the strength as very good.
2-3 is eh....
Sometimes into 6th is a little easy to hit R..... <grind>
1st is low low low.... Super granny....
Other than that and the fact that mine is in the shop right now for a hydraulic clutch assembly problem... rate as good...
JEEPLESS... :(
azcoyote is offline
post #8 of 26 Old 10-03-2006, 07:15 PM
Laxstar46
personally i like the six speed because on the highway drives my five speed wit the 4 cyl is hittin about 3k rpm at 70 mph. which is killer on the mpg. the six gives it a bit higher of a gear to keep rpm's down on hgihway
Laxstar46 is offline
post #9 of 26 Old 10-03-2006, 07:26 PM
neZZr
neZZr's Avatar
Actually the 5 speed has a better overdrive ratio than the 6 speed... so at the same speed with the same tire size & rear axle gears, the 6 speed Jeep will turn a higher RPM.
neZZr is offline
post #10 of 26 Old 10-03-2006, 07:35 PM
dl425
I have an 05 six speed. 1-2 is a little notchy, especially on cold mornings, but you learn how to do it right, and when it's warmed up you don't even notice it.
I've never driven one with the 5spd so I don't know whether it's better or worse.
2005 Red Rocky Mountain Edition
4.0 6 speed
Jeeperman Skidz-Body Armor front and rear bumpers
Rocky Mountain Edition Club Member #2
dl425 is offline
post #11 of 26 Old 10-03-2006, 08:07 PM
JeepMKcomin
slight notchiness, most went away after i changed my tranny fluid to synchromax
06TJ Silver Ruby - REBB w/DT3000s, Quick Discos, Superwinch EPi9.0, Warn engine skid, PS Box Skid, Diff Guards, IPF Lenses, x51s soon
92YJ White - Slight Shackle Lift w/30x9.5 BFG ATs, Custom Beefy Bumpers
06TJ Khaki Sport - Traded in
JeepMKcomin is offline
post #12 of 26 Old 10-03-2006, 08:19 PM
BLACK05X
2-3 is eh....
What kind of problem were you having with your clutch. The reason i ask is because ive been having a problem with my clutch also.
I agree with all that was said above. My six speed is notchy and crunches once in a while when going to gear.
2005 Black Wrangler X
4.0 Liter 6 speed
BLACK05X is offline
post #13 of 26 Old 10-03-2006, 08:47 PM
JeepinYahoo
JeepinYahoo's Avatar
1977 CJ5
Mine has has al kinds of problems. I lost 4th adn 6th gear on a raod trip to california(conveinient, try cali rush hour with half a tranny). The warranty covered it but all the internals were coming unscrewed. When I went to drain the fluid a bolt fell out the hole. It was weird. Not to say it isnt good, but it has had plenty of trouble. 15,000 on the ticker at the time.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100
JeepinYahoo is offline
post #14 of 26 Old 10-04-2006, 01:00 AM
rayar3
If Jeeps could fly...
rayar3's Avatar
Mine has it's "issues." The 2-3 notch is there, but it seems to have gone away after 10k miles (prolly ground the gears nice and round)...
Reverse sometimes takes some persuading, but other than that I don't have any complaints.
1st gear is almost never used, unless I feel like getting a good laugh out of my friends as the tires chirp into second while I pass a Maxima or something off the line...and I know I'm too old for that...
2000 XJ 2-door (current)
2006 65th Anniversary TJ (sold)
rayar3 is offline
post #15 of 26 Old 10-04-2006, 08:39 AM
anebrich
I've had both the 6sp and 5sp (AX-5 - 4cyl.) and I've been happy with both of them. Like stated before, drive it like a tractor and you'll be fine.
anebrich is offline
2005 6 speed tranny question harleymike TJ Wrangler Technical Forum 92 01-14-2010 06:10 PM
will a NP231 J TC from a six speed XJ Tranny work for an AX-15 Tranny New2Jeepin TJ Wrangler Technical Forum 3 12-07-2009 04:36 PM
6 speed tranny question ncopp TJ Wrangler Technical Forum 6 08-19-2009 10:25 AM
5 speed to 6 speed tranny swap? motox704 TJ Wrangler Technical Forum 0 01-23-2009 02:44 AM
3 speed Auto Tranny Question (1998) 4cyl alexr40 TJ Wrangler Technical Forum 1 10-07-2008 05:04 PM
