06 Rubicon Speedo Bouncing - JeepForum.com
post #1 of 8 Old 02-06-2014, 02:29 PM Thread Starter
LRod
Been going over "Bouncing Speedo" in Search and haven't come up with one solution to my problem, more like ideas of what it could be, like crank position sensor, speed sensor, wheel sensor, loose wires, dirty elect. connections, frayed wires and none for a 06 TJ. My speedo bounces around 40+ mph and faster. Any body with a similar problem?
LRod is offline
post #2 of 8 Old 02-06-2014, 04:30 PM
CharlieHo
I, don't have a problem with mine, but, I remember reading something in my JB Conversions SS SYE about that.
Check that the sensor on you TC output housing is not loose or something dumb.
Originally Posted by mdm
You could ask it nicely to move over. When that doesn't work, get a bar or 2x4 and ask it again.
I have the ability to spell correctly, it's just that the autocorrect on my iPad will not permit it.
CharlieHo is offline
post #3 of 8 Old 02-06-2014, 05:27 PM Thread Starter
LRod
thanks for the reply Charlie I've messed with just about everything except changing out the cluster circuit board, so I guess that's the next step. Although it may be a combination of circumstances??
LRod is offline
post #4 of 8 Old 02-06-2014, 09:21 PM
JPNinPA
Check this
http://www.stu-offroad.com/engine/speedo/speed1.htm
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
post #5 of 8 Old 02-06-2014, 09:41 PM
bondosgto
1994 XJ Cherokee
If you have a rubi, you have an electronic speed sensor I do believe. So I would check out the blue monkey set-up.
bondosgto is offline
post #6 of 8 Old 02-06-2014, 10:23 PM Thread Starter
LRod
I have a 06 Rubicon with an electronic sensor, it different than the one shown. I didn't want to make this a long story but... about a year ago, the pin that holds the "Tone" ring in place on the output shaft popped out of place and got between the ring and sensor. It dented and pushed the sensor out of the housing and blew ATF under the jeep. When I got home I pulled the tailcone and replaced the pin with the same tone ring. It all worked great till about a week ago when the needle started bouncing. The tone ring has a nick in it, but has worked ever since. I've cleaned the contacts on the cluster board plugs, and "Silver" screws that connect the board to the actual gauges, switched speed sensor on the tranny, reset computer, checked for 5v at the socket by the speed sensor, cleaned the grounding connections under the LH speaker cover, so far. It has gotten better , in that it doesn't start bouncing till it gets to 40mph. Have I missed anything other than replacing the gauge cluster circuit board?
LRod is offline
post #7 of 8 Old 02-07-2014, 06:25 AM
JPNinPA
True! Didn't catch that.
JPNinPA is offline
post #8 of 8 Old 02-07-2014, 12:09 PM Thread Starter
LRod
"Blue Monkey" ?????
LRod is offline
