#1 | |
06 rubicon rocker height
Hey guys, dad just bought an 06 TJ rubicon, and is unsure if it has a lift kit already or not. Since Im 4 hours away, I cant simply pop over and check.
What im wondering is what is the stock height from ground to rocker panel on an 06 (or same) Rubicon. Then to figure if it has been lifted, I could go like this right: stock Rocker height - (31/2) = XX" modded rocker height - (tire size/2) = YY" then to figure if it has been lifted, and how much, go YY-XX = ZZ where ZZ is the approximate lift ammount. EDIT: Dads tires are 285 75 R16's, which I see to be about 32.8" x 11.2". And the rocker height is exactly 24". So with my calculations, the YY is ~7.6", anyone know what the XX is?
#2 |
no one out there with a stock rubicon willing to go out and get some measurments?
#3 |
Mine sits 19" from the floor to the bottom of the rocker guard, measuring roughly in the middle front/rear. It's factory stock so I hope that gives you the info you're looking for.
Flame Red 2005 Rubicon Unlimited, 4.0L, 6sp, dual tops, Valvoline VR-1 10w30 engine oil/M0-090 Mopar filter, Amsoil Synchromesh 5W30 trans. oil, IPF 920hc head light conversion with PIAA Xtreme White plus bulbs, PIAA Xtreme White Plus H-3 fogs, Armadillo front/rear bumper caps and Olympic grille guard. Amsoil SevereGear 75W140. |
#4 |
Just violated my Parole
it has a lift on it. how much i cant tell you. but 33" tires wont fit without at least a 2" BB
#5 | |
Do you still have the stock 31" tires? Assuming you did have the stock tires, and if my thinking is right, it works out dad having a 3.7" lift, so Im going to guess either a 2" BB and BL, or a 3.5" lift, or a 4" lift. Thanks to the both of you guys ^^ |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
