Top tank of my radiator just split about 4" and seeping coolant. Any recommendations on a replacement??? One row two row, aluminum ??
I have and automatic trans and want to keep the quick connections on the oil cooler.
First, I also recommend the Mopar as recommended above. Next, the number of rows in a radiator does not directly correlate to how well it cools, the OE Mopar with its single row aluminum core generally cools better than most aftermarket radiators with 2, 3, or even 4 rows. In fact, the TJ first came out with a 2 row radiator but went to a different 1 row radiator design around 1990 or 1991 for better cooling characteristics.
The Mopar Model # is 55037653AC which you may find cheaper elsewhere. Yep that radiator isn't cheap but it will work fine. Aftermarket radiators are a real crap shoot and few will cool as well even if they (naively) brag about having more than 1 row.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
