Does anyone know the MOPAR Part number for an 2006 Jeep Rubicon NP241J output shaft seal retainer?? The casting that holds the seal??? or better yet does anyone have one??:surprise::surprise:
I'm pulling the numbers directly out of the 2006 factory part number catalog. The part number listed for the 241 transfer case is as I posted above, the one for the 231 is P/N 5017477AA.
03 to 05 lists 5093606AA for the 241. I don't have an 06 parts manual but you should be able to find out if that number also applies to 06.
EDIT: MoparPartsGiant shows 5166072aa for 05 and 06 but also shows 5093606aa for 03 and 05. Maybe the number changed mid 05.
A call to the dealer with your VIN is a way to confirm.
EDIT: I recalled a TSB about leaking around the rear output, TSB 21-003-04 had you replace the retainer and associated seals. There was a later update to the TSB that listed 5166072aa as a modified retainer with a groove machined into it.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
