'05 TJ Rubicon driveline vibes? Rear CV driveshaft questions - JeepForum.com
post #1 of 16 Old 09-14-2017, 01:04 PM Thread Starter
RandyEpisodes
Junior Member
Hey everyone, I recently purchased my second TJ and am in need of some help tracking down the cause of a vibration. For reference, the jeep had already been built a good bit by a previous owner, so I'm a little unsure of the exact specs on some of the mods, but I'm guessing it has about 4-6" of lift because it is currently running 35's.
So, now to describe the issue. When accelerating, I'm getting a slight vibration between 20-25mph. Doesn't matter which gear I'm in and only occurs on throttle. I feel the vibration mostly in the gas pedal. Does this sound like a driveline issue? The fact that it only occurs in a small window of speed and not a specific rpm range makes it seem more like an out of balance tire or steering linkage issue but I don't feel anything in the steering wheel. I know one of the TRE's at the drag link needs to be replaced (going in Saturday along with an OEM style pitman arm), could this be the cause of the vib?
Also, this jeep doesn't have a CV driveshaft installed or TC drop, so I know that is something that will need to be addressed sooner rather than later, but if I can wait a month or two to do it, it would be ideal. If the driveshaft is the issue, what additional parts would I need to do the job correctly? IIRC the rubicon's do not have a slip yolk, so no SYE? Are adjustable control arms absolutely necessary? Uppers and lowers?
Thanks for the help.
RandyEpisodes is offline
post #2 of 16 Old 09-14-2017, 08:16 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
With the amount of suspension lift that you have it would be recommended to have the adjustable control arms (upper and lower) and the DC drive shaft...
Knuckelhead is offline
post #3 of 16 Old 09-15-2017, 12:38 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
X 2.
Originally Posted by jeepinmichguy_ View Post
TheBoogieman is a jerk.
Why also would he need a rare as hen's teeth Dana 44 out of another TJ which will eventually lead to him swapping in a POS 8.8 because he can't find one?
TheBoogieman is offline
post #4 of 16 Old 09-15-2017, 12:42 AM
TheBoogieman
Does it have a MML? BL? Pics of lift?
post #5 of 16 Old 09-15-2017, 07:03 AM Thread Starter
RandyEpisodes
Junior Member
No body lift, unsure about a MML, I'll try to go out and take a look when I go to lunch later and snap a few pics.
post #6 of 16 Old 09-15-2017, 07:09 AM Thread Starter
RandyEpisodes
Junior Member
Yeah, when I bought this thing I expected to have to go back and fix all the previous owner's crap/laziness. I definitely plan on doing a CV shaft and new control arms as soon as possible, its just a matter of what order to address the issues. Hopefully I will have the time to get the pitman arm and TRE on tomorrow. Its also kicking a P0134 code (bank two O2 sensor/cat) that needs to be replaced, so stuff just keeps piling up. Good thing its payday
post #7 of 16 Old 09-15-2017, 08:08 AM
TheBoogieman
Just asking about pics to determine how much lift you have because I recently lifted my Rubi 4.25" total (3" SL/1.25" BL) and was surprised that I didn't need a MML or t case drop and no vibes. I plan on running 35's when I get more cash.
post #8 of 16 Old 09-15-2017, 08:35 AM Thread Starter
RandyEpisodes
Junior Member
Gotcha. I ran a 3.5" RE lift & 33's on my 99 TJ that I had before. I did a 1" TC drop and never had a problem with vibes, but it was an automatic with the np231 and D35 rear which would yield substantially different driveline lengths and angles.
Unfortunately with this one the PO did all of the work so I'm still going through and figuring out what they actually did to it. I know its running at least 4" of SL, maybe more and sitting on 35's. I was shocked that they didn't do at least a TC drop, but I figure if I'm going to do it I might as well do it right and spring for the CV and new control arms.
post #9 of 16 Old 09-15-2017, 09:52 AM
TheBoogieman
If the vibes are minimal, a MML and 1/2" t case drop would fix it until you want to spend all the extra money to "DO it right". Of my 17 Jeeps, I used a MML and 1/2" t case drop on all but one, to get rid of all vibes with a 4" SL and 35's.The one with adjustable CA's didn't do anything better except empty my wallet and give me the ability to say "I did it right". I prefer to do it "wrong" and spend my money on other things.
post #10 of 16 Old 09-15-2017, 09:53 AM
TheBoogieman
It doesn't.
post #11 of 16 Old 09-15-2017, 10:11 AM Thread Starter
RandyEpisodes
Junior Member
Hahaha, your secret is safe with me I just went out to take a look, no MML on mine. I'll have to look into that option, are there any other major mods that need to be done along with the MML? I'd assume the radiator would have to come up a tick as well to clear the fan, anything else you've run into when doing it?
post #12 of 16 Old 09-15-2017, 05:55 PM
TheBoogieman
Doing a BL with the MML is a good option. Just the MML requires moving the fan shroud like you mentioned. Pretty straight forward installation.
post #13 of 16 Old 09-15-2017, 07:41 PM
Knuckelhead
AFSOC Retired
What do you plan on doing with your Jeep?
Mall crawl or exploring trails?...
post #14 of 16 Old 09-18-2017, 12:21 PM Thread Starter
RandyEpisodes
Junior Member
Hey Knuckelhead, it will primarily be my daily driver but mild/moderate trail rides aren't out of the realm of possibilities. The plan is to build it as much as I can over the next couple of years while I finish paying it off and once that's out of the way it will make the transition into a designated weekend funmobile.
post #15 of 16 Old 09-18-2017, 05:45 PM
coach-mike
I had a similar issue with my Last LJ it was the Drive shaft Ujoint
coach-mike is offline
