05 TJ Rubicon / Dana 44 - JeepForum.com
post #1 of 13 Old 06-04-2009, 11:20 PM Thread Starter
Verno
Does the lower ball joints have grease zerks ?
Verno is offline
post #2 of 13 Old 06-04-2009, 11:25 PM
red rubi
So long pal!
red rubi's Avatar
Without running outside to check I would say yes. IIRC there are 7 grease zerks up front.
Welcome!
red rubi is offline
post #3 of 13 Old 06-04-2009, 11:27 PM
RogueSpear2023
Mine do.
10 char
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #4 of 13 Old 06-04-2009, 11:28 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Originally Posted by RogueSpear2023 View Post
Mine do.
10 char
What stops the yokes on the axle shaft from mowing them off?
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #5 of 13 Old 06-04-2009, 11:36 PM
red rubi
So long pal!
red rubi's Avatar
There's your answer!
red rubi is offline
post #6 of 13 Old 06-04-2009, 11:39 PM Thread Starter
Verno
Well mine don't, It looks like it has a plug on top, nothing on the bottom by the castle nut.
Verno is offline
post #7 of 13 Old 06-04-2009, 11:42 PM
mudb8
want it rite or rite now?
mudb8's Avatar
that's what i'm thinking....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #8 of 13 Old 06-04-2009, 11:48 PM
red rubi
So long pal!
red rubi's Avatar
I think Mrblaine was trying to say the lowers don't have zerks, and seriously if anybody would know...
red rubi is offline
post #9 of 13 Old 06-04-2009, 11:52 PM Thread Starter
Verno
Well I just saw this post.
http://www.jeepforum.com/forum/showt...ght=ball+joint
I guess I get to save a little grease, thanks for the fast replies.
Were you guy's able to view the pics in the links, just wondering, not sure how to post actual pics.
Verno is offline
post #10 of 13 Old 06-05-2009, 12:01 AM
red rubi
So long pal!
red rubi's Avatar
You need to be a paying member or some such rule
Until then just like that, a little smaller please
red rubi is offline
post #11 of 13 Old 06-05-2009, 12:16 AM Thread Starter
Verno
Sweet, thanks.
Verno is offline
post #12 of 13 Old 06-05-2009, 12:39 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Depending on who makes them, there are two styles of that lower balljoint and because it's used in some applications where there is room for the grease fitting, they thread it for one.
The TJ uses much larger axle shafts that are closer to the lower, so if you get the ones that are threaded, you just grease them good when you install them, remove the zerk and install the plug.
I am Savvy
mrblaine is offline
post #13 of 13 Old 06-05-2009, 01:55 AM
mudb8
mudb8's Avatar
this one is greasable....
if you pull the axle shaft, and install a zerk in place of the cap plug, pump er full of grease, then put the cap plug back in and the rest of the axle you had to tear down...
mudb8 is offline
High pinion dana 30 vs rubicon dana 44 mustgooverit TJ Wrangler Technical Forum 17 04-28-2011 01:20 PM
Dana 44 rubicon axles vs Dana 30/35 combo Arcticcat843 TJ Wrangler Technical Forum 15 07-26-2008 12:01 AM
ARB in Rubicon dana 44 conrasm TJ Wrangler Technical Forum 2 08-02-2007 09:28 PM
Rubicon Dana 44 gets hot 06rubicon TJ Wrangler Technical Forum 21 03-09-2007 02:42 PM
Dana 35 to Dana 44 out of a 2005 Rubicon Kobi13 TJ Wrangler Technical Forum 9 02-02-2006 06:55 AM
