'05 TJ Overheating... - JeepForum.com
post #1 of 8 Old 08-01-2013, 09:30 AM Thread Starter
fxs16
Randomly overheating. I'll drive for 30 minutes no problem then I will drive to the store three minute ride and temp will shoot up to 260. I cranked up the heater and oddly the air coming out was not warm. I had been leaking coolant a few days ago. I used a product called liquid aluminum I found at Autozone. Leaking stopped but now I'm overheating at random times.
Any thoughts would be appreciated. Also there is a bubbling sound coming from the overflow tank.
Thanks,
Frank
fxs16 is offline
post #2 of 8 Old 08-01-2013, 09:33 AM
wwch99tj
The bubbling is from the radiator cap not holding the correct pressure. Have you checked the coolant level?
Sent from my Samsung Galaxy S3 using JeepForum
wwch99tj is offline
post #3 of 8 Old 08-01-2013, 09:38 AM Thread Starter
fxs16
Coolant level is good. Overflow is also between add and full.
fxs16 is offline
post #4 of 8 Old 08-01-2013, 10:09 AM
frenchy206
Buy a new radiator cap with the correct pressure rating. Next, you probably need to burp the system. Many times air pockets are in the cooling system. Squeeze the top radiator hose, while the cap is off. You will probably find air. Keep doing this until all the air is gone. This should solve your problem.
03 TJ Rubicon
frenchy206 is offline
post #5 of 8 Old 08-01-2013, 12:02 PM Thread Starter
fxs16
Sayers the hose? Typo? If not please explain.
fxs16 is offline
post #6 of 8 Old 08-01-2013, 12:04 PM
biffgnar
biffgnar's Avatar
Squeeze
Romney in 2020!
biffgnar is offline
post #7 of 8 Old 08-01-2013, 12:34 PM
j_bydesign
Wrench Wheel Repeat
j_bydesign's Avatar
I think we need to come up with the definition for Sayers... could be a cool or HOT term! gotta love spell check!
'04 TJ(wheeler) '65 CJ5(sold :( )...'05 LJ(Scrambler conversion) 89' Int. Harvester Toter (get the TJ to and from)! '80 CJ7 Resto Mod(sold) 1985 CJ7 Renegade (in process)
j_bydesign is offline
post #8 of 8 Old 08-01-2013, 02:11 PM
frenchy206
Phone app + about to board plane + lack of sleep = possibility for type o. Yes squeeze.
03 TJ Rubicon
coolant , overheating , radiator , thermostat
