05 TJ looking for d60 and chevy 14b - JeepForum.com
post #1 of 5 Old 03-27-2008, 02:35 PM Thread Starter
2005X
what im wondering is where do i look, what vehicle should i look at. im wanting to run D60 up front and the 14 bolt rear. right now im just looking at gathering parts for a slow build. i know later wil come issues with new wheels, regearing, and transfer case. but now im just worried about the axles
2005X is offline
post #2 of 5 Old 03-28-2008, 08:40 AM Thread Starter
2005X
anybody, what year and make should i be looking at pulling off a D60 for the front of my TJ, and chevy bolt 14 for the rear
2005X is offline
post #3 of 5 Old 03-28-2008, 04:06 PM
moparjunkee
There are a couple of things that you will need to look into and decide now in order to find your front axle. You need to decide what T-case you are going to run because this will decide what side your diff needs to be on. For the 14 bolt, all of your 80's and maybe even into the late 70's chev 3500's will have this. Any of your 3500(GM) models, 350 (ford and dodge) is going to have a D60 in the front. I do know that you will be better off with the king pin style(stronger) instead of the ball joint and I think that the king pin style is the only model that you can run a high steer kit. I am also pretty sure it would also be a big bonus if you could get one out of a ford because in certain years they are high pinion, but then again you need to know with side you want the diff before you go hunting. I would probably post on the full size forum and see if anyone has more information.
Good luck and happy hunting
No matter how far you go, there you are.
moparjunkee is offline
post #4 of 5 Old 03-28-2008, 04:11 PM
V-8unlimited
I have what you need, complete set of 60,000 mile dana 60 kingpin chevy frontend and matching 14 bolt rear. I was planning to use them in my tj with ps drop atlas, but I think Currie 9" HP's are in my future.
V-8unlimited is offline
post #5 of 5 Old 03-28-2008, 04:23 PM
alex71
I would look for a ford 60 front. It would be to much work to make a Chevy 60 work because of the pass side axle. Most go for 500-1000 and you can find a 14 bolt for cheap.
2001 jeep wrangler sport / Waggy 44 /FORD 8.8. lockright/ 4.88 / 3/2'' lift,Stretched to 100.5/ Warn x8000i / 35in BF KM2's / AtoZ rockers, cage,/ Poison spyder crusher corners.
Vote for TJOFTY!
alex71 is offline
Chevy 5x4.75 on a YJ? gettrdone YJ Wrangler Technical Forum 8 06-04-2009 11:57 AM
5.7 Chevy MODUS TJ Wrangler Technical Forum 0 03-14-2009 05:43 AM
Chevy V 8 355 in yj? daddoty YJ Wrangler Technical Forum 1 05-28-2007 07:15 PM
350 Chevy sb in a YJ? 81CJ7Renegade YJ Wrangler Technical Forum 4 05-18-2006 07:08 PM
Chevy 350 W/ Chevy Tranny - Will It Work??? I8JPB4U YJ Wrangler Technical Forum 5 09-16-2004 10:53 PM
