05 TJ Lift Suggestions - 2" lift and 33" tires - Page 3 - JeepForum.com
post #31 of 46 Old 07-17-2010, 12:12 AM
emev0l
If your only driving it on the street and not off roading it you can run 33" tires with 2" coil spring spacers.
I would not personally do it.
You would be a lot happier if you also installed a 1.25 body lift with the 2" spacers.
Your also going to need around 1" longer bump stops if you run it with a body lift and 2" of extra bump stop if you run it without the body lift.
Your going to bounce off your bump stops over speed bumps if you have 2" coil spring spacers and 2" longer bump stops.
I would not do this, it's not a very good way to run 33's.
For the most part, your going to want at least 3" of total lift to fit 33's, and 4" of total lift for 35's
If you wanna go cheap either buy the 2" coil spring spacers and a 1.25" body lift or buy a Rough Country 3.25" suspension lift.
2001 TJ 4.6 Auto 4.5" AEV suspension 35's
2002 TJ 4.0 Manual 3" BDS suspension 33's
1987 Chevy 1 Ton 12" suspension 44's
1970 Cutlass 442 468CID TH400
1999 7.3 Powerstroke
emev0l is offline
post #32 of 46 Old 07-17-2010, 02:06 AM
mudb8
want it rite or rite now?
mudb8's Avatar
why not? 2" lift, 2" bumpstop extension and 33's are the same as stock with 31's, which stinks for uptravel but it's still the same.....
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #33 of 46 Old 07-17-2010, 05:55 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Originally Posted by Dangermouse View Post
Them Texas plates I see? What part of Texas? I got a Willys edition and I ain't seen another out here yet.
My brother bought it from someone in Texas on Ebay with 3500 miles on it.It's in Va now.
TheBoogieman is offline
post #34 of 46 Old 07-17-2010, 08:38 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Originally Posted by OlllllllllO View Post
I disco now with a 1.25" body lift and im still fine....
then you have more than 2 inches dont you.....
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #35 of 46 Old 07-17-2010, 08:40 AM
jeepinmichguy_
Soar Forever Six
depends on the backspacing of the rims.
ΜΟΛΩΝ ΛΑΒΕ
post #36 of 46 Old 07-17-2010, 09:11 AM Thread Starter
bowserw
Well after everyone's helpful info (THANKS SO MUCH!) I've basically decided to go one of two routes.
Either:
1. Run a 3" lift kit that includes springs, front sway bar disconnects and rear sway bar links, rear track bar relocation bracket, bump stop extensions, transfer case lowering kit, and shocks and go with 33s
or
2. Run a 2" BB and go with 32s
I'm leaning towards the 3" kit. Now I need to figure out exactly what tire/wheel set up I want to use and how the back spacking is going to work out.... and then the gearing... and then how I'm going to mount a full size spare with out it getting in the way of my kayak rack....
Thanks again for all the input!
bowserw is offline
post #37 of 46 Old 07-17-2010, 09:33 AM
DH19922010
Either:
or
Go with option number one and go with bds ($730 for basic 3in) if you don't wanna spend a lot but want a nice ride. You'll want your backspacing to be between 3.5-4.5 in, For gearing, if you plan on staying with 33's, 4.56 would be a good ratio. I have plans of going to 35's so i geared to 4.88's right away because you'll only want to regear once. Its expensive
DH19922010 is offline
post #38 of 46 Old 07-19-2010, 06:54 AM
emev0l
Exactly why I wouldn't do it, crappy up travel, it does look pretty mean though.
An ex gf of mine had a 97 TJ with 33" Thornbirds (yeah I know I didn't like them either) and she was running 2" coil spacers.
It was fine as long as you didn't hit any bumps or go up a steep incline, but why have a jeep if you can't do either?
It will work, but I wouldn't do it.
emev0l is offline
post #39 of 46 Old 07-19-2010, 06:56 AM
emev0l
The 3" BDS is a nice riding lift.
emev0l is offline
post #40 of 46 Old 07-28-2010, 04:36 PM
mgoodric
So I am running Metal Cloak Tube Fenders, and recently upgraded to 35's. I went wheeling last weekend, and fully expected some rubbing. I did rub a little bit, so in the next few weeks I am looking at getting a 2" lift. At first I was looking at getting the JKS ACOS's and some longer shocks, but after reading this thread I am not sure what I should do. Any advice?
03 Sahara 4.0 5spd - MetalCloak Arched Tube Fenders, MetalCloak Rear Corners, MetalCloak Rocker Rails Cobra 75 WX ST, Goodyear Wrangler MT/R with Kevlar, Rough Country 2.5" Long Arm, LoD Xpedition Series Bumper/Tire Carrier w/Trail Package
mgoodric is offline
post #41 of 46 Old 07-28-2010, 05:49 PM
OlllllllO
OlllllllO's Avatar
i'm running 2" spacers w/rubi unlimted springs and 33x10.50's on 15x7's w/4" backspacing on my 4 cyl TJ with no rubbing at all at full flex. the suspension package gave me about 3-3.5" and the best part is it only cost 100 bucks for used stuff. bumpstops are only 1" longer then stock, rides a little rougher then other lifts but its a jeep
back jeepin again....
OlllllllO is offline
post #42 of 46 Old 07-29-2010, 07:50 AM
emev0l
Where exactly did you rub?
emev0l is offline
post #43 of 46 Old 07-29-2010, 08:28 AM
mgoodric
My rear tires rubbed a bit on the tab that is on the front side of the rear fender well. Those seem to have gotten bent enough that Is not a problem, I also stuffed the rear well pretty well.
The front tire rubbed once or twice on the rear of my front metal cloaks. See pictures below.
mgoodric is offline
post #44 of 46 Old 07-29-2010, 08:39 AM
Eagle7
How is your spare going to get in the way of a kayak rack - do you have a rack over your cab? I use a conga cage - and have no problem with 33s. I did have to move the spare up a couple of inches to get access to my hitch on the bumper. For that you can redrill the stock mount holes -- or purchase an aftermarket tire carrier that fits in the stock holes but moves it up.
Eagle7 is offline
post #45 of 46 Old 07-29-2010, 08:42 AM
cgork
I have 285 75R16 tires, 2" spring spacers, 1" body lift, 1.25" wheel spacers. Trimmed the fender flares for good measure. I get "MAYBE" some minor rubbing at full flex, but that's it. I love this set up. I don't think my rubicon is any different when it comes to lifting than any other TJ. I could be wrong though.
cgork is offline
tj , wrangler , lift , suspension , budget boost , bb , 33" , tire
Suggestions pleas (lift for 33" tires) Dante18 TJ Wrangler Technical Forum 16 03-01-2010 07:00 AM
2-inch lift/32inch tires suggestions for TJ sport bstew417 TJ Wrangler Technical Forum 9 11-15-2009 05:21 PM
Suspension Lift VS Body Lift......TIRES? TCzyzak TJ Wrangler Technical Forum 20 06-23-2009 08:51 PM
4in suspension lift + 2in shackles + 2in body lift = 35in tires? snou52 YJ Wrangler Technical Forum 24 03-22-2009 06:21 AM
cost and suggestions for lift..tires..rims lXl Rebel Wrangler lXl YJ Wrangler Technical Forum 3 07-28-2002 10:38 PM
