05 TJ Lift Suggestions - 2" lift and 33" tires - JeepForum.com
post #1 of 46 Old 07-13-2010, 09:28 PM Thread Starter
bowserw
First off, I'm sure this question has been asked about a thousand times, so sorry for that. I tried searching for an answer, but all I get is conflicting info and bits of things that make sense, but also bring with them more questions.
I have a 2005 TJ "X" with stock wheels and suspension. My tire tread is getting to the point to where its time to get new tires and i want to upgrade. I was thinking 32 or 33 inch tires, probably 33s. I'll probably put them 15 x 8 Cragar Soft 8 wheels.
I was thinking about just doing a budget boost of 2" with spacers and shocks. First off can I fit 33's with a 2" boost? This is my daily driver and i have no plans of doing any off roading, will anything rub or hit?
Do I need anything else with the 2" boost? I hear a lot about needing to lower the transfer case, or pitman arm, or having to use a HD steering stabilizer or anything else.
Thanks in advance, i'm practically to the point of banging my head against the wall.
bowserw is offline
post #2 of 46 Old 07-13-2010, 09:33 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
GOLENJEEPTJ is offline
post #3 of 46 Old 07-13-2010, 09:34 PM
bddisi
bddisi is offline
post #4 of 46 Old 07-13-2010, 09:40 PM
SugarBear
1969 CJ5
If you don't look at those links , I'm sure you can clear 33's with no off-roading. A 2' BB and the tires would fit fine.
A TC drop isn't necessary with a 2" BB.
Just order the lift and the tires and you'll be good to go.
1969 CJ5
2.5" Rancho Kit/Shocks/Steering Stabilizer, 2" Shackles, Koenig PTO Winch, 31x10.5x15 Cooper STT's
SugarBear is offline
post #5 of 46 Old 07-14-2010, 09:38 AM Thread Starter
bowserw
Thanks for the quick replies!
I actually already tried going through the forum FAQ and quick links stuff and it didnt really help me. I have seen the tire fit guides too, but I also have heard people saying that you could get away with tires bigger than what most guides say, just like SugarBear said.
Does any one have 33" tires with only a 2" lift or did anyone?
Also, if I do go with a 3" lift, do I need to drop the transfer case or do anything else?
Thanks again.
bowserw is offline
post #6 of 46 Old 07-14-2010, 10:09 AM
leaf777
I installed a 2" BB on my TJ a couple of years ago, I ran 31's, the only other item I had to replace was my sway bar links up front. They were about $20 each. Unless you have the factory option Dana 44 with 3.73 gears I would not recommend 33's. I drove the 2" lift for years with no problems, a $250 2" BB and maybe $150 for a 1 1/4" BL & MML is an easy install. It will not require an SYE or new driveshaft or any other parts.
leaf777 is offline
post #7 of 46 Old 07-14-2010, 10:55 AM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
I've never had to drop the t case or do a MML with any 2" lift I've installed.That being said,all Jeeps are different. My neighbor has been running 33x12.50's with a 2" BB for several years.
TheBoogieman is offline
post #8 of 46 Old 07-14-2010, 12:17 PM Thread Starter
bowserw
I'm a little slow on some of the abbreviations, MML? SYE?
Has your neighbor had any problems? Is that pic his Jeep?
Thanks again to everyone!
bowserw is offline
post #9 of 46 Old 07-14-2010, 12:23 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
A 2" suspension lift does not (!) provide enough clearance for 33" tires. 3" is the bare minimum with 4" recommended for offroad use of those 33" tires. At the minimum you should also install a 1" body lift which with a 2" suspension lift will provide 3" of clearance.
Jerry Bransford is offline
post #10 of 46 Old 07-14-2010, 01:09 PM Thread Starter
bowserw
If I do a 2" suspension lift w/ a 1" body lift, if a Transfer Case drop necessary?
bowserw is offline
post #11 of 46 Old 07-14-2010, 01:18 PM
Jerry Bransford
Administrator
50:50 yes or no on that. Some TJs need a mild t-case drop with only a 2" suspension lift, most do not however. At most, a 1/2" t-case drop should be enough to cure any mild vibrations, if they develop, ofter installing the 2" suspension lift. You can accomplish that easily with nothing more than longer replacement t-case skidplate mounting bolts (they are metric and need to be rated at 10.9 or 12.9 for hardness) and washers stacked up around the bolts between the frame and skidplate to give the 1/2" drop. Due to the indentation around each of the bolt holes in some model year skidplates, you'd need slightly more than a half-inch stack of washers around the bolts to actually give you that 1/2" drop.
post #12 of 46 Old 07-14-2010, 01:37 PM
leaf777
BB= budget boost = 2" coilspacer lift.... BL= body lift..... MML= motor mount lift.... SYE = slip yoke eliminator.... I agree with Jerry, you can get away with 2" & 33's, but in my opinion you should also install a 1" body lift for the extra clearance, I suggest a motor mount lift to acompany the BL to allow the drivetrain to follow the body upwards 1inch. The MML will help move your t-case shifter, trans. shifter, and radiator fan move closer to their original positions relative to your body. You should not need an SYE with a lift of less than 4". Bre sure to adjust your toe-in after the install.
leaf777 is offline
post #13 of 46 Old 07-14-2010, 02:33 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Jerry, its about bumpstops
4" of lift clears 33s because it has 2" bumpstops, whether that be from the 15" collapsed length 10" travel shocks bottoming out or real bumpstops to prevent those shocks from bottoming out. Even if you have 6" of lift, you won't clear 33s if you can fully compress the stock bumpstops (which you cant due to shock length, but bear with me). there just isn't enough room from the center of the tire assembly to the top of the fender when the stock bumpstops are fully compressed...hence you add bumpstop extension, BL or highline fenders
You can run 33s on a 2" lift, with 2" bumpstop extension. or 2" lift + 1" bumpstop extension and 1" BL. or a 3" BL. or stock with 2" bumpstop extension and hardly any uptravel.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #14 of 46 Old 07-14-2010, 03:08 PM
TheBoogieman
That's my brother's Jeep before he installed a 1" BL.The pic was for reference.My neighbor hasn't had any problems and wheels it.He lengthened his bumpstops.
post #15 of 46 Old 07-14-2010, 03:31 PM
Jerry Bransford
Administrator
You oversimplify a situation that is far more than just about bumpstops which does a disservice to a guy just trying to set his Jeep up properly. If it were only bumpstops, we'd be able to run 40" tires with just extra-tall bumpstops.
tj , wrangler , lift , suspension , budget boost , bb , 33" , tire
Suggestions pleas (lift for 33" tires) Dante18 TJ Wrangler Technical Forum 16 03-01-2010 07:00 AM
2-inch lift/32inch tires suggestions for TJ sport bstew417 TJ Wrangler Technical Forum 9 11-15-2009 05:21 PM
Suspension Lift VS Body Lift......TIRES? TCzyzak TJ Wrangler Technical Forum 20 06-23-2009 08:51 PM
4in suspension lift + 2in shackles + 2in body lift = 35in tires? snou52 YJ Wrangler Technical Forum 24 03-22-2009 06:21 AM
cost and suggestions for lift..tires..rims lXl Rebel Wrangler lXl YJ Wrangler Technical Forum 3 07-28-2002 10:38 PM
