'05 TJ ECM computer reflashing? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > '05 TJ ECM computer reflashing?
CHASSIS SAVER™ Rust Preventive Paint Memorial Day Weekend RuffStuff Memorial Day Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-24-2010, 03:44 PM   #1
idiot magnet
I just got back from the jeep dealership and they told me my used ECM can't be reflashed with my Jeeps VIN.
My computer is toast, so I bought a good used one and was told they could be reflashed.
Can it be reflashed?
Who can reflash it?
Do I return it and buy a refurbished one for $375 from the stealership?
Will it work in my Jeep the way it is?
Thank you for any help with this.
A rebuilt '05 Unlimited w/ 6 spd, 4.0, 3" BDS springs, front locker, warn front bumper, PS corners, rock sliders and the list goes on and on.
Former Jeeps: 79 CJ7, 81 CJ7 Renegade, 85 CJ7 and a 95 YJ.
Project car: Big Block 4spd 69 mach 1 (it's back on the rotisserie for the final time).
[FONT="Palatino Linotype"][FONT="Comic Sans MS"]Indyorv.com[/FONT][/FONT]
idiot magnet is offline   Reply With Quote
Unread 03-24-2010, 04:44 PM   #2
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
The Dealership service department and the parts department will tell you can't do something or can't buy some part because they are lazy or want to sell you parts you do not need.
Find a more customer service oriented dealership, as long as the PCM is correct for your Jeep, it can be re-flashed.
Progressive Liberalism: Bringing you new ideas so wonderful, they have to include mandatory participation ......
Originally Posted by Ronald W. Reagan
Government is not the solution to our problem; Government is the problem.
CJ7-Tim is offline   Reply With Quote
Unread 05-12-2010, 02:20 PM   #3
KaptinNemo
where can i get a re-flash, and about how much should it be?
KaptinNemo is offline   Reply With Quote
Unread 05-13-2010, 06:27 AM   #4
Bubba3200
And what does re-flashing the PMC really do??
Bubba3200 is offline   Reply With Quote
Unread 05-13-2010, 06:39 AM   #5
Zen
The PCM has your vin number stored in it. As part of the uncle sam required checks, if the vin does not match it won't work. The dealership/service shop gets a software package that includes the most current set of rules/parameters for the engine and downloads that allong with your vin as an update. Chances are if you have old software to begin with the Jeep will run better after the reflash then it did before your old ECM took a crap.
I think any shop with the correct Chrysler OBD scan tool can reflash the ECM for you. That includes little mom and pop shops. Call around and if they don't do it, ask them where they get it done.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline   Reply With Quote
Unread 05-13-2010, 08:08 AM   #6
Neil F.
Ok maybe it is not applicable to the Jeep ECM but I own another Chrysler product (99 Dodge Durango). I know for a fact with the Durango (Dakota and Ram) that the VIN in the PCM (as it is called with the Durango) has no affect on it's operation. I have swapped a couple PCM into mine (with the original owners VIN), sold my stock PCM, and many other owner have swapped PCMs.
The question on reprogramming a VIN in the Durango PCM also has come up on those forums and all the information indicates that it cannot be changed by the dealer. But again it does not need to be to run.
Neil F. is offline   Reply With Quote
Unread 05-13-2010, 10:41 AM   #7
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
Who can reflash it?
1. Maybe - You need a PCM from the SAME YEAR and SAME TRANSMISSION.
2. The dealer can reflash it - which is where I would go, they have the StarSCAN tool with all the latest and greatest software downloaded directly from Chrysler. The new software is really the only reason to get it reflashed anyway.
3. As long as yours meets #1, its fine.
4. Maybe, it has to meet #1. If it meets #1, I bet you could install it, drive to the stealership and them have them reflash it.
Unlimited04 is offline   Reply With Quote
