05 Rubi gears on an 06 non-Rubi? - JeepForum.com
post #1 of 8 Old 02-12-2007, 08:03 PM Thread Starter
surfcaster
Will a set of 4.10 gears from an 05 Rubi Unlimited fit in an 06 non-Rubi Unlimited. They are both Dana 44's. The only reason I'm asking is that the Rubi has a locking differential and the non rubis have lsd. Also, is the front differential on the 06 unlimited the same as the rear? Have a chance to get a set of 4.10's and was wondering if they will work. Thanks in advance......
surfcaster is offline
post #2 of 8 Old 02-12-2007, 08:04 PM
Rocky529
Rocky529's Avatar
The Unlimited has a Dana 44 rear and a Dana 30 front. Only the Rubicon has the matching pair of 44s.
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline
post #3 of 8 Old 02-12-2007, 08:05 PM
SecondTJ
SecondTJ's Avatar
The front diff in a non-rubi unlimited is a Dana 30, so the front gears would not work
'98 Sport, 4.0, AX-15, D44, 3.73, stock w/ 10k original miles
Gone - 2000 Sport, 1987 YJ, 1997 SE, 1998 XJ
SecondTJ is offline
post #4 of 8 Old 02-12-2007, 08:27 PM
BlaineWasHere
BecauseRacecar
BlaineWasHere's Avatar
I don't think the rear gears would work in a non-rubi D44. Don't those use a dfferent R&P? I know Randy's has a different part number for them.
2013 FR-S
BlaineWasHere is offline
post #5 of 8 Old 02-13-2007, 03:04 PM Thread Starter
surfcaster
OK, the front is a D30 and rear is D44. Would they fit the rear?? Obviously I would have to then purchase ones for the front seperate.
post #6 of 8 Old 02-13-2007, 03:56 PM
NoUse328
If you have a Rubi carrier handy, yes they'd work. If not, they're thick cut gears and I don't believe they'll fit in a standard d44.
NoUse328 is offline
post #7 of 8 Old 02-13-2007, 03:58 PM
Bigbob
Bigbob's Avatar
No. The Rubi carrier and the regular 44 carrier are different. The gear sets are not interchangable.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #8 of 8 Old 02-13-2007, 05:29 PM Thread Starter
surfcaster
Thanks guys, I'm going to have to go another route for gear. It's to bad too, because I could have the gears for both axles for under $100.
3.54 gears on a Rubi air locker? RockRodHooligan TJ Wrangler Technical Forum 7 01-12-2010 10:57 AM
Rear Rubi locker in front Rubi axle. NotURMailman TJ Wrangler Technical Forum 4 05-08-2009 10:56 PM
D44 Rubi Gears gmd JK Wrangler Technical Forum 10 02-25-2009 11:14 AM
06 rubi gears daver032 TJ Wrangler Technical Forum 2 06-26-2007 03:42 PM
4.88 gears with 33s on a Rubi toastervet TJ Wrangler Technical Forum 20 09-23-2006 06:37 PM
