04 Wont start with Key - JeepForum.com
post #1 of 6 Old 10-26-2012, 06:00 PM Thread Starter
trent4589
So hopefully someone on here can help me out, ive looked online and everywhere possible to fix the problem but cant seem to find it. hes what i have so far.
2004 jeep wrangler sport 4x4 4.0l inline 6 5spd
when i go to turn the key it does not turn over, it does make a click noise from the glove compartment though.. i replace the starter so far and i can start the truck sometime by touching the relay to turn over the motor while the key is in the on position. i have bypassed the clutch position sensor so i can leave it in neutral and try to crank it by the relay. but when i try to crank it with the key i get nothing but the click from glove box. it will also start by popping the clutch out on a hill.. i am stumped and have no ideal where to go from now... the ignition fuse under hood is ok and so is the one behind the glove box. if u have any ideals ill take them! thanks!
trent4589 is offline
post #2 of 6 Old 10-26-2012, 06:33 PM
2jhanna
battery and/or grounds would be my next try.
jhanna
denton county, tx
2jhanna is offline
post #3 of 6 Old 10-26-2012, 06:38 PM
Yucca-man
Definitely check the battery.
Yucca-man is offline
post #4 of 6 Old 10-26-2012, 06:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Turn the headlights on and while watching them, have a helper turn the ignition key to Start. What do the head lights do when the key is in the Start position? Do they dim/go out or do they stay at full brightness?
Gone wheeling Friday through Sunday.
Our Technical Staff is working to fix our database error problem, thank you for your patience.
Getting
Jerry Bransford is online now
post #5 of 6 Old 10-26-2012, 07:44 PM Thread Starter
trent4589
Battery is fine I've narrowed it down to inbetween the switch and starter relay.. Is there anything between those two things that could be it?
post #6 of 6 Old 10-26-2012, 08:28 PM
JPNinPA
Clean the connection is to the starter and all grounds. Could be the Ignition switch.
"Never look down on anyone unless your helping them up"- Jesse Jackson
JPNinPA is offline
fuse , relay , starter , switch
