'04 Rubicon Only Starts on Second Try - JeepForum.com
post #1 of 10 Old 12-01-2010, 06:04 PM Thread Starter
kduren1
Hi all. My wife's '04 Rubicon only starts on the second try. I've been snooping around on this and other forums for some time trying to figure out the problem. Thus far I have cleaned the TB, replaced the Fuel Pressure Regulator, the IAC Motor, and the CKP Sensor. No luck.
Initially the problem manifested itself as long-ish crank times before starting (3-4 sec). It has since progressed to cranking for as long as you're turning the key and still not starting. As soon as you let off and try again, it starts right up.
I haven't tested the fuel pressure (no test port), but I have tried the vise grip trick with no luck. Leaving the key on for a while and then trying to start does not help either. Theres no gas in the oil--injectors seem fine. So, I don't think it's a fuel problem.
I did get a IAC malfunction fault code, but that was only after I cleaned it and did not get the plug back on completely. Replaced the IAC just for fun. No luck, but no codes.
While I was spending money and reading forums replaced the CKP and the spark plugs as well. After replacing all that, the jeep started the first time right away....once. No luck on subsequent tries.
I have checked all the wires and plugs including the CPS and TPS. God battery too. Nothing seems to be working.
HELP I AM PULLING MY HAIR OUT! At this point in time it's about pride...I am determined to fix this thing myself!
kduren1 is offline
post #2 of 10 Old 12-01-2010, 06:27 PM
superslayer
Could be the fuel pump check valve..
Heres a writeup on how to fix it:
DailyDrivenTJ-Fuel Pump Repair
superslayer is offline
post #3 of 10 Old 12-01-2010, 06:34 PM Thread Starter
kduren1
Copy, I already replaced the fuel pressure regulator. Shouldn't a new one keep fuel from draining back into the tank if a bad check valve is indeed the problem?
kduren1 is offline
post #4 of 10 Old 12-01-2010, 06:46 PM
KKiowaTJ
My XJ had that problem. I took my old front 02 sensor from my TJ and swapped them out and it has started right off ever since. Could be the problem, Maybe not but thats the symptoms i had and what i did to fix it. Good luck
MOPAR!
KKiowaTJ is offline
post #5 of 10 Old 12-01-2010, 07:03 PM
Steve98
I would get an inline gauge and check fuel pressure. Most of the Jeeps I've seen do this, leaving the key in the ON position for a few seconds always helped. It runs the fuel pump and builds pressure.
2006 LJ Rubicon
Steve98 is offline
post #6 of 10 Old 12-01-2010, 07:09 PM
Imped
Imped's Avatar
That's odd. It doesn't seem like O2 sensors and fuel pressure would have any correlation. I have the same problem....new fuel regulator didn't do a thing. New fuel pump assembly didn't do a thing. New injectors didn't do a thing. The fuel pump is an Airtex unit and I haven't heard the best things about that company. I'm thinking about swapping it out and trying something else. There has to be a reason for this and it's quite annoying.
OlllllllO
IndyORV
Imped is offline
post #7 of 10 Old 12-01-2010, 07:14 PM
KKiowaTJ
It fixed the XJ. My 98' Sahara has had everything you said and a new distributor and it still lags at start up. I gave up on it long ago and just prime the system when i want to drive it.
Only thing i can come up with, The 02 regulates how much rich/lean and if it has soot covered 02 might not read correctly. But thats just a shot in the dark, No fact behind that at all.
MOPAR!
KKiowaTJ is offline
post #8 of 10 Old 12-01-2010, 07:18 PM
scottbr
2016 JK Wrangler
I dunno about the 04's but my 97 TJ will only run the pump for a second or two when the key is turned to run position, not enough to pressurize a flat fuel system. I believe it is controlled by the ECU. I would turn the key to run then off a couple of times before I started it so it wouldn't crank so much.
Then the problem just went away.
scottbr is offline
post #9 of 10 Old 12-01-2010, 07:22 PM
Imped
Imped's Avatar
Yeah, sometimes mine starts up quick, sometimes it cranks forever and I have to crank it a second time. Obviously pressure is being allowed to escape somewhere. It's a problem no matter how you look at it. Mine used to start right up and just started hard starting out of nowhere. It's been tough to track down, that's for sure.
OlllllllO
IndyORV
Imped is offline
post #10 of 10 Old 12-01-2010, 08:41 PM Thread Starter
kduren1
Hmmm, so you think it may be a fuel problem? Come to think of it, the problem did seem to get worse after installing a new Fuel Pressure Regulator. Either installed incorrectly (probably not the case), it's faulty or there's no check valve in the replacement part.
I've also heard it could potentially be a bad CPS. Seems as though the engine would run bad if that were the case.
I've also read that the fuel pressure will drop to 0 in the line and that's normal as long as fuel stays in the line.
Perplexed...
kduren1 is offline
ckp , cps , iac , starting problem , tps
only starts on 2nd try... method84 TJ Wrangler Technical Forum 26 08-30-2010 01:03 PM
89 YJ only starts sometimes Boris61 YJ Wrangler Technical Forum 1 07-17-2009 10:12 AM
Starts, Idles, Dies, Wont Start, Wont Start, Pump Pedal, Starts... REPEAT inniett YJ Wrangler Technical Forum 2 04-08-2009 04:13 PM
At least it starts! ragweed13 TJ Wrangler Technical Forum 2 06-26-2007 10:36 PM
Usually starts, sometimes doesn't mizzoumurad YJ Wrangler Technical Forum 1 10-05-2005 07:41 AM
