04 Rubicon Dana 44 locker help - JeepForum.com
post #1 of 9 Old 04-02-2012, 11:14 PM Thread Starter
oreyca
Hey there all, this is my first real forum experience so if my etiquette isn't 100% please feel free to politely let me know.
So anyways, I have an 04 TJ Rubicon that I did axle seals on this weekend. (Dana 44/216 FBI with Tru-Lock). While I had the differential assembly on the bench I noticed the cross shaft or center pin retaining pin is loose and slides freely inside the diff case and the cross shaft. Because of the diff cases contour the pin cannot completely slide out (if it could, i probably would have learned it was loose the hard way......kaboom!!!). Jeep only sells the entire diff case assembly(locker, spider gears, cross shaft, ect.) for a measly $1800.00. At $1800.00 my logic says 'make it work'. So I was wondering if anyone else has run across this and come up with a creative fix or even knows how the retaining pin is removed. In the pictures you can see the end of the cross shaft or center pin between the ring gear teeth. Gravity alone is enough to allow the retaining pin to slide. In the second pic I'm holding the retaining pin up in it's correct position. Thanks for any help you can offer.
oreyca is offline
post #2 of 9 Old 04-04-2012, 10:46 PM Thread Starter
oreyca
Pictures
Just reposting pics in hopes that all can see.
oreyca is offline
post #3 of 9 Old 04-05-2012, 01:10 AM
bojang
Why is the actuator so far away from the diff? Where are the gears that are supposed to be in there that lock the diff together?
Chris
Freedom from nags, cranks, government, do-gooders, control-freaks and idiots is all that I ask for.
Never trust a lumpy fart.
bojang is offline
post #4 of 9 Old 04-05-2012, 07:03 AM Thread Starter
oreyca
The actuator is so far away from the diff because the side bearing cap is what retains and locates it and in the pictures the cap is not installed. the locker assembly is between the spider gears and the actuator. The front doesn't have a series of gears but I think the rear does because it's limited slip as well. The gears in the rear are for the LSD I think.
oreyca is offline
post #5 of 9 Old 04-05-2012, 09:42 PM Thread Starter
oreyca
oreyca is offline
post #6 of 9 Old 04-05-2012, 10:05 PM
mike78
This is exactley what mine looked like. I pulled the carrier to replace my axle seals and found the cross shaft pin in same spot. I have no clue what to do? Should I pull the bearing and replace the diapragm, I thought this was most likely the problem first but I think there may be more to it, or just start over and use a hp dana 30 with an aussie. I just want my locker too work Im ready to wheel and now I have an open front diff. The axel is pretty beat so I do not want to dump alot of money into it.
mike78 is offline
post #7 of 9 Old 04-05-2012, 10:07 PM
Heath
2014 JK Wrangler
Buy a Detroit. Problem solved.
2013 JKU Rubicon
Heath is offline
post #8 of 9 Old 04-06-2012, 01:28 AM
bojang
Mine locked and unlocked. I've been looking for an exploded diagram but I haven't found it yet.....
Wondering if the actuator was where it was supposed to be, if the locking gears retain the pin?
Chris
bojang is offline
post #9 of 9 Old 04-06-2012, 05:12 AM
dkrajcovic
An ARB will fix that
dkrajcovic is offline
dana 44 , rubicon
Rubicon Dana 44 Front locker air line 143DAD TJ Wrangler Technical Forum 5 12-21-2011 11:18 PM
High pinion dana 30 vs rubicon dana 44 mustgooverit TJ Wrangler Technical Forum 17 04-28-2011 12:20 PM
Can an Aussie Locker for a Dana 35 be altered and used in a Dana 30 Front JGEORGE TJ Wrangler Technical Forum 3 02-18-2011 08:03 AM
Dana 30 "Lockright Locker" shaft C-Clip Locker? clarkjdg YJ Wrangler Technical Forum 2 03-11-2010 08:07 PM
Dana 44 rubicon axles vs Dana 30/35 combo Arcticcat843 TJ Wrangler Technical Forum 15 07-25-2008 11:01 PM
