04 lj rough/low idle in drive - JeepForum.com
post #1 of 10 Old 05-12-2012, 06:42 PM Thread Starter
APEDZ04LJ
ok so 04 lj, im geting a intermitent rough/low idle at a stop in drive, goes down to the first dot on the tach, already cleaned the iac, had autolite 985s in it, im gonna try ngks tomorow, i read a bad tps? or fuel pressure? how can i test fuel pressure?
APEDZ04LJ is offline
post #2 of 10 Old 05-12-2012, 06:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Probably a sticky/dirty IAC (idle air control) which is what provides all of the engine's air at idle when you're not stepping on the accelerator pedal. The IAC is a solenoid actuated plunger that moves in and out of an oriface in the throttle body to provide the engine's air at idle. The IAC's plunger and the oriface (hole) in the throttle body can be cleaned with throttle body cleaner and restored back to good operation.
Jerry Bransford is offline
post #3 of 10 Old 05-12-2012, 07:02 PM Thread Starter
APEDZ04LJ
i already pulled the i ac and the tb apart and cleaned it all out, it wasent that dirty, still have the problem
post #4 of 10 Old 05-12-2012, 07:14 PM Thread Starter
APEDZ04LJ
post #5 of 10 Old 05-12-2012, 11:14 PM
55willystruck
Can you define "wasn't that dirty" and describe how you cleaned it?
I will tell you this-I can't count the number of rigs I've cured this issue on after folks have told me the exact same thing...
To clean properly, you MUST remove everything, and scrub every nook and cranny with a tooth brush thoroughly using a good TB cleaner. Exercise the plunger on the IAC and scrub it too, along with opening the throttle plate and removing the haze around the ring. You want a mirror finish here on all of it-if you don't have that, it isn't clean enough. Absolutely no haze or dark color of any kind-if you have that, it isn't clean enough and it will lead to rough idle and surge conditions. Sorry, not that I don't trust your cleaning job, but I've been told that more times than I can count and it wasn't clean enough which lead to the same issues you have here.
How many miles on the rig and is it totally stock? You don't have one of those screwy jet chips or anything like that do you? No TB spacers or other gimmicks?
Stick with factory plugs as well-regular NGKs are hard to beat.
Best of Luck,
Mike
55willystruck is offline
post #6 of 10 Old 05-18-2012, 12:20 PM Thread Starter
APEDZ04LJ
Ok so i tried new plugs, and a new iac and that didnt solve it
post #7 of 10 Old 05-18-2012, 06:58 PM Thread Starter
APEDZ04LJ
bump for an anwser on what i should look at next
post #8 of 10 Old 05-18-2012, 07:02 PM
threeb
Any codes from the computer? I had a cylinder not firing due to my ignition rail pack on the #4 cylinder going bad.
LJ Owners Group member #431.
threeb is offline
post #9 of 10 Old 05-18-2012, 07:29 PM Thread Starter
APEDZ04LJ
Nope no codes
post #10 of 10 Old 07-24-2012, 06:55 PM Thread Starter
APEDZ04LJ
bumping for update, ive sprayed all vaccum lines and nothing changed rpm wise, ive tryed another throttle body with all different sensors, it still surges at idle but now at start up it revs up to 1800 then idles at 1100, it also know surges while cruising only for a certain gear, i have no clue whats going on here and no codes at all
2004 TJ 4.0 High Idle after Drive, but then normal idle greenjeepsrule TJ Wrangler Technical Forum 6 11-07-2012 11:52 AM
rough idle idle issue rescue913 YJ Wrangler Technical Forum 1 10-21-2010 06:57 PM
Rough idle after 1/2 mile drive... NEED HELP!!! poobub TJ Wrangler Technical Forum 8 07-27-2009 04:24 PM
Idle Air Controller - Trying to Clean for Rough Idle - Need Help JBWood05TJ TJ Wrangler Technical Forum 21 08-24-2008 06:40 AM
Carter BBD fix for No Idle or Rough Idle ScotZ YJ Wrangler Technical Forum 0 03-26-2003 09:26 PM
