'03 Wrangler Blower Motor Resistor Help - JeepForum.com
post #1 of 17 Old 09-30-2008, 10:35 AM Thread Starter
gpschmidt
Does anyone have a diagram or picture of where the blower motor resistor is exactly located behind the glove box of a Wrangler? For the life of me I can't seem to locate it. Is is up under the glovebox? Thanks.
Greg
gpschmidt is offline
post #2 of 17 Old 09-30-2008, 11:01 AM
otisdog
2008 WK
FSM for 03:
The blower motor resistor is mounted to the bottom of the heater-AC housing on the passenger side of the vehicle under the instrument panel. It can be accessed for service by removing the instrument panel glovebox.
It also says it can't be serviced - must be replaced
Jim
08 Grand Cherokee Overland
otisdog is offline
post #3 of 17 Old 09-30-2008, 11:34 AM
SpitNine
2015 JK Wrangler
Been There, Twice
[QUOTE=gpschmidt;5775040]Does anyone have a diagram or picture of where the blower motor resistor is exactly located behind the glove box of a Wrangler? For the life of me I can't seem to locate it. Is is up under the glovebox? Thanks. [QUOTE]
The glove box has to come out.
If you have the factory under dash lights, remove the light under the glove box.
Two hex head screws hold the resistor assembly in place.
One of them is hard to reach.
Do not try to unplug the old resistor until you remove it.
Plug in the new resistor before installing it.
I have found it much easier to replace the resistor by removing the passenger door or at least unhooking the door strap and holding the door out of the way somehow.
Thanks.
2015 Sport
Six Speed
Hardtop
Fire Cracker Red
SpitNine is offline
post #4 of 17 Old 09-30-2008, 11:53 AM Thread Starter
gpschmidt
Cool, I do have the light. Thanks.
post #5 of 17 Old 09-30-2008, 01:05 PM
john NC
john NC's Avatar
1979 CJ5
from my 05 FSM, i believe it's the same for 03+
john NC is offline
post #6 of 17 Old 09-30-2008, 06:48 PM Thread Starter
gpschmidt
Ok, got it swapped out! Thanks for all the help!
Greg
post #7 of 17 Old 03-05-2009, 11:28 AM
djem
Help!
How the heck do you pull the harness plug out from the resistor after unlocking the red tab?
I've tried to wiglle this thing free and it doesn't seem to budge. Any tips/pointers to help me pry this thing out before I totally lose my mind?
Thanks in advance.
dj
djem is offline
post #8 of 17 Old 03-05-2009, 01:22 PM
Jackle
should be the red clip which you have to pop backwards to unlock the red tab....then there should be a push in style disconnect that you have to push in and wiggle at the same time.
Jackle is offline
post #9 of 17 Old 03-05-2009, 11:19 PM
djem
Thanks man. I'll look for the 'push-in' part of the disconnect.
Boy, it's tight in there. By the time I get this done it'll be spring and I won't need that darn blower.
djem is offline
post #10 of 17 Old 05-12-2009, 07:12 PM
estoddart
I have the same problem with the '02 TJ I just bought.
Just wanted to say thanks for the info posted, I'll soon be replacing the resistor and gettin my blower back to normal.
Does anyone have a suggestion on where to pick up this part for cheap?
estoddart is offline
post #11 of 17 Old 10-17-2009, 11:55 AM
snofrog
I just picked one up at the dealer for $20.89 including tax . how much cheaper do you need it to be ?
snofrog is offline
post #12 of 17 Old 10-17-2009, 12:02 PM
murzi3000
I bought one from NAPA for $23.59 plus tax. Part # BR256.
Back in '82, I used to be able to throw a pigskin a quarter mile.
murzi3000 is offline
post #13 of 17 Old 08-19-2010, 10:11 AM
MaxPower49
Digging up an old thread here, but thanks for the info. My 1 and 2 speeds on the fan had stopped working. Did a little it of searching, found this thread... got a blower resistor for $17.99 +tax from Napa and not have 4 speeds on my blower again. I'm sure the stealership would have charged me $100+ for this easy fix. Well.. pretty easy... that thing is a pain in the *** to get to.
Anyways, thanks for the info!
MaxPower49 is offline
post #14 of 17 Old 08-25-2011, 11:24 AM
dakidd
On my 99 Wrangler. Knob position # 3 won't work . Put in new resistor with no results . Position 3 is my favorite , sometimes 2 isn't enough & 4 is to much . Anyone been thru this before have answers or help ? Hate to start tearing the dash apart ( again ) to check the switch itself but might be the problem . Is there relays involved that need to be checked ? Thanks from Canton Ohio .
dakidd is offline
post #15 of 17 Old 08-25-2011, 02:13 PM
JWebber
There is a relay but it's for all 1,2,3, and 4 postions 1,2,3 are on the resistor speed pak while 4 is bypassed (high) if three is dead your switch is either melted due to the blower fan drawing too many amps, pull off center panel and pull out a/c control panel look at switch on back. If any wires or harness or metal tabs looks heated or melted, replace the cheap switch and go by a new blower fan motor. If you just replace the switch you will be doing this again and again until you replace the blower motor fan.
JWebber is offline
If it's not my blower motor resistor, it's my what??? blower still doesn't turn on.. bortz1892 TJ Wrangler Technical Forum 13 08-02-2010 09:13 PM
blower motor AND resistor bad??? andieopie Wrangler General Discussion 0 08-26-2009 07:26 AM
Blower motor resistor? crazbuck14 TJ Wrangler Technical Forum 0 12-06-2007 03:05 PM
blower motor resistor $$$$$ mudluva TJ Wrangler Technical Forum 6 02-27-2007 12:51 PM
Blower motor resistor location in a 1997 wrangler Laxstar46 TJ Wrangler Technical Forum 3 01-02-2007 08:19 PM
