03 Jeep TJ noise? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 03 Jeep TJ noise?
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 04-14-2015, 10:32 PM   #1
jax03tj
03 Jeep TJ noise?
I have a faint knock/ click noise when rolling up to a redlight( low speed less than 10 mph. You only here it at lower speeds. It sounds like a older car speedo cable click. Any ideas? Thanks everyone!
jax03tj is offline   Reply With Quote Quick reply to this message
Unread 04-15-2015, 05:51 AM   #2
dos0711
Take out the front drive shaft and see if it goes away...
263
2000 Wrangler TJ, 4.0 6 cyl, A/T, 3.07 gears...ugh.
dos0711 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2015, 12:05 PM   #3
JFM626
It would be nice if you could isolate it a little more. Have a friend duplicate your actions, while you stand outside and listen for where the noise is coming from--- front, back, left side, right side etc.
How can you trust an atom, they make up everything
JFM626 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2015, 04:18 PM   #4
chevy2169
Crawl under the jeep and wiggle the driveshafts. There should be no play. Also wiggle the two front axle shafts, there should be no play.
Some say a comet will fall from the sky.
Followed by meteor showers and tidal waves.
Followed by faultlines that cannot sit still.
Followed by millions of dumbfounded dipsh**s.
chevy2169 is offline   Reply With Quote Quick reply to this message
Unread 04-15-2015, 11:14 PM   #5
jax03tj
I didnt get a chance to take the drive shaft off today, however I just rebuilt all of them a few weeks ago including the centering yoke.
Unread 04-15-2015, 11:31 PM   #6
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Have you rebuilt a driveshaft with a DC joint before?
Also, for future discussions it helps if you fill in your profile...
TSB Information: http://www.automd.com/tsb/jeep_m/wrangler_mm/2000_y/
Knuckelhead is offline   Reply With Quote Quick reply to this message
Unread 04-17-2015, 05:20 AM   #7
Airstreamer67
Do you have an automatic locker?
Airstreamer67 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 07:25 PM   #8
jax03tj
I put a whole new dc joint. And no i dont have lockers
