03-04 Compass / Temp rear mirror Questions Help! - JeepForum.com
post #1 of 9 Old 12-29-2003, 01:25 PM Thread Starter
Tmsnake1
I just installed an original Wrangler Temp / Compass Mirror on my 04 Wrangler. The install is Simple and took less than 5min. I have two problems that maybe someone can help me with.
My mirror will not display the temp correctly. It only reads 0C degrees. I can not get it to switch over to Fahrenheit or display anything besides 0C. The compass works perfectly as well as the lights on the mirror. Anyhelp at all would be great. Thanks!
2002 Wrangler Sport - destroyed by drunk!
2004 Wrangler Rubicon -Yellow, 5spd
I
Tmsnake1 is offline
post #2 of 9 Old 12-29-2003, 01:37 PM
JeepinBlue24
JeepinBlue24's Avatar
Is the thermomter wire run for it? I believe the thermometer is in front of the radiator, if I am not mixing my cars up here.
1995 YJ: Just got her.
Planning:
Dynatrac 60s w/SOA
36 or 38 IROKs
..and keeping the 4banger until she dies!
JeepinBlue24 is offline
post #3 of 9 Old 12-29-2003, 03:34 PM Thread Starter
Tmsnake1
There is a Wire harness that the mirror plugs in to. All wranglers have this harness reguardless if they have this mirror. I guess incase they decide to install it later. Anyway, my point is there is only one harness that the mirror can be pluged in to. I dont think I have to run anymore more Wires.
I
Tmsnake1 is offline
post #4 of 9 Old 12-29-2003, 03:43 PM
Jeepin_Al
Just taking it easy!
it is a standard wiring harness but I doubt they put the thermometer probe in just like they didn't put a mirror in, ask your local dealer and they will probably sell you a probe for a few bucks and should have a diagram of where it is located for you in the computer, just ask and they will normally show you on the computer parts screen, AL
"rejected by the signature police"
Jeepin_Al is offline
post #5 of 9 Old 12-29-2003, 05:43 PM
kgordon7378
on my 03 which is equiped with the temp/direction mirror from factory, you have three lights on the mirror, the outer ones turn on the lights for each side. The center one, if you push it changes the degree measurements, (from C to F, and back) and if you hold the button for five seconds it disables the auto dimming feature, which then turns off the green light on the mirror. HTH. Keith
kgordon7378 is offline
post #6 of 9 Old 12-29-2003, 05:51 PM
DouginTN
DouginTN's Avatar
Did you get the mirror from the dealer, or online?
DouginTN is offline
post #7 of 9 Old 12-29-2003, 10:26 PM
dub
btt
I too would like to know where to get this magic mirror.
ken
2004 Wrangler Sport - Very Yellow
2004 Grand Cherokee Laredo - Wife's ride
2001 Dodge Ram 2500 CTD - I love the smell of diesel in the morning.
dub is offline
post #8 of 9 Old 12-30-2003, 12:45 AM Thread Starter
Tmsnake1
I figured it out!! 1st off, i got the mirror through an online dealer. Its aprox. $200 and comes with everything you need.
The problem is, is that I forgot to install the T-stat. It was in the box but I never saw it. Very small. About the size of a pinky. Its easly installs behind the girll. THe harness is already installed so all i did was plug it in and bolt i down. Took 30sec. Now Everything is working 100%
Thanks for the help!!
I
Tmsnake1 is offline
post #9 of 9 Old 12-30-2003, 04:45 AM
stonethrowertj
Maybe he got it here?
$239 from jeepsareus
stonethrowertj is offline
Rear View Mirror with Compass and Temp SportTJ4x4 TJ Wrangler Technical Forum 65 08-09-2012 10:54 PM
Rear View Mirror with Temp/Compass? MusicMaverick TJ Wrangler Technical Forum 2 04-14-2008 04:44 PM
Mirror compass temp problem skruske TJ Wrangler Technical Forum 1 08-17-2007 06:08 AM
Temp/Compass Mirror Hiccup? ironpony TJ Wrangler Technical Forum 5 11-09-2005 11:49 PM
temp/compass mirror? silverstone01 TJ Wrangler Technical Forum 5 10-08-2004 08:21 PM
