02 tj trans extension housing leaking? - JeepForum.com
post #1 of 4 Old 08-02-2010, 04:30 PM Thread Starter
lukefj80
i have an 02 wrangler with a 4.0 with an auto trans with a 231 transfer case. my transfer case broke in half when my front drive shaft ujoint went out. i replaced the case with a used 99 cherokee sport 231 out of a friends jeep. i replaced the output seal on the transmission. i drove it and found a leak coming from the hole in the extension housing between the trans and tcase. i pulled the case again and couldnt find any issues. i replaced the transmission output seal again and the tcase input seal and resealed. the leak is just as bad. anyone ever have this issue? please help!
lukefj80 is offline
post #2 of 4 Old 08-02-2010, 05:34 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Odds are very good that the 231 you installed was configured to bolt to a 5-speed transmission which means its input shaft is too short to seal where it enters the auto tranny's output shaft seal. The easy fix is to install an extended output shaft seal into the auto tranny which is sold by a number of sources like either Advance Adapters or JB Conversions (one or the other I can't remember) and Tera. This moves the seal itself further out a tad where it can properly seal against the 231's shorter input shaft.
Here's the one at Tera where I got mine since mine did the same thing after converting my 5-speed tranny to the same tranny you have.
Automatic Seal Extension | TeraFlex Suspensions
And a big welcome to JF!
Jerry Bransford is offline
post #3 of 4 Old 02-07-2012, 10:33 PM
TheStigX
I know this thread is more than a year old but I figured it wasn't worth it creating a new thread. Would this extended transmission seal work on an NV3550 and a NP231 from an automatic Cherokee? I'm going to be purchasing this transfer case in a few days to put in my Jeep if this indeed works the other way around too.
Is this the correct one also?
http://www.teraflex.biz/automatic-se...on.html#second
It didn't seem that deep...
TheStigX is offline
post #4 of 4 Old 02-08-2012, 06:36 AM
mrblaine
Wizard of Brakes
mrblaine's Avatar
One or two of the manuals in the TJ, and for sure the later 6 speed don't need input seals at the t-case because they are sealed separately.
I believe the 3550 is as well, so maybe dig around on the 'net and see if you can find out for sure.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
leak , leaking , transmission , tranny , housing , np231 , tj , wrangler
Thermostat housing leaking jeepster1976 YJ Wrangler Technical Forum 12 06-10-2010 08:45 AM
Thermostat housing wont stop leaking manofmany TJ Wrangler Technical Forum 8 11-08-2007 10:58 AM
Help NEED NP231 Extension Housing Cone NamesMUD YJ Wrangler Technical Forum 5 07-06-2006 01:28 PM
rear extension housing... broke again...! Wingmaster YJ Wrangler Technical Forum 4 04-13-2005 12:49 PM
Transfer case Extension housing rpickett YJ Wrangler Technical Forum 11 09-10-2004 12:11 PM
