02 sensors help - JeepForum.com
post #1 of 5 Old 05-13-2013, 08:54 PM Thread Starter
rhovater
02 sensors help
I recently did a swap. I put in a 2000 4.0. I had to buy the engine harness and comp separate. My question is most tj s 2000 up have the mini cats w 4 o2 sensors. My harness has 4 connector but one of them is on the passenger side of the engine near the starter area. The other 3 are on the drivers side. I'm not sure what is going on here with this harness or where my sensors should go. Is this a model that does not required the mini cats? Thanks
MY 97/2000 TJ HYBRID
rhovater is offline
post #2 of 5 Old 05-13-2013, 11:23 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Moved to TJ Forum, I think you'll get better replies here.
Wheelin98TJ is offline
post #3 of 5 Old 05-14-2013, 12:02 AM Thread Starter
rhovater
Thanks....this has been a pita.
rhovater is offline
post #4 of 5 Old 05-14-2013, 12:42 AM
mchadpayne
Mine has four 02 sensors and if I remember correctly the rear down stream rear sensor comes across the top of the bell housing from the passenger side. It has the mini cats also
mchadpayne is offline
post #5 of 5 Old 05-14-2013, 12:47 AM Thread Starter
rhovater
Strange set up....black plug left front, black and gray left rear of engine and then the passenger side ia the other gray...I am probably going to have to swap out my exhaust system.
rhovater is offline
