| Moto Alliance Viper Elite 8,000lb Winch Giveaway! |
| Jeep Registry | Register | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
Why is your palm red?
02 fog light wiring question
#2 |
On the Hella 500's I just installed on my TJ the relay is wired with one wire to power, one to ground and the third to the high beam power. When I turn on my high beams the fogs turn off. you could probably hook to the high beam wire off of the turn signal switch high beam wire.
#3 |
I'm not wanting to do a complete rewire of the lights I am only wanting info on what wire coming out of the switch controls the fog-lights. I would just install a new switch but I have checked dealerships, parts stores and online and cant find a switch for a 2002 tj with fog-lamps in stock. Everyone is telling me 60 - 90 days back order on the switch.
So if I can find the wire coming out of the old switch that controls the lights I will hook it to another switch untill I can track down a new factory style switch |
#4 |
If anyone knows of a place that would have a Headlight switch for a 2002 TJ with foglights in stock let me know.
#5 |
Just had a look at rockauto they say up to 42 days...
So, wire from headlamp switch you want is red/orange to feed the fog lamp relay coil. The pink/light green wire going into switch is the one that normally supplies the power to the fog lamp relay. If you tap both of them and put a switch between them your fog lights will come on with the switch. One thing to note when the fog lamp stops working properly, is that some times they can come on without the ignition and could leave you with a flat battery. To stop that happening you can remove the foglamp relay, but if you wanted the fog lamps working you might have to snip the red/orange wire to prevent them coming on at random, but still come on via the switch you want to add. When you do get a new switch you'd have to rejoin the red/orange wire to resume normal function.
"Giving English to an American is like giving sex to a child. He knows it's important but he doesn't know what to do with it." Adam Cooper (19th century) JF has helped us all, now its time to return the favor! http://www.jeepforum.com/forum/f6/support-jeepforum-equipment-drive-963790/ |
#6 |
Fog light sensitivity, turn signal trouble and a mysterious beep
Look at post # 6, thats what i did to just wired in a regular switch bypassing the steering column one.
2002 tj sahara 3" lift 33"bfg at, AtoZ rockers 10k winch 1997 xj 4dr 3" lift 31" bfg at 10klb winch RC rock sliders My jeeps Carolina Offroad Forum Coastal Carolina Offroad East Coast Trail Raiders |
#7 |
Thanks for the info.
#8 |
Cool. I got the same issue too. Time to look for the factory switch that fits by the lighter
Scott Vosevich |
#9 |
jeep4x4center.com is showing on there website that they have the switches in stock. I am going to call in a bit and if so I can get one from them before I go cutting up the wires.
#10 |
#11 |
www.theknutters.com
Is this what you are looking for? I did the same thing after my fog lights would mysterously turn themselves on in my 02 Sahara. Cut the White wire with the orn tracer and rerun to your new switch. If you just splice into it chances are the original switch will still mess with you.
#12 |
Scott Vosevich |
#13 |
Found some on EBay
http://motors.shop.ebay.com/i.html?_nkw=fog%20light%20switch&_dmpt=Motors_Car_ Truck_Parts_Accessories&_fln=1&_ssov=1&_trksid=p45 06.c0.m282&Make=Jeep
Scott Vosevich |
#14 | |
#15 | |
The one I was looking for is this multipurpose switch Multi Function Switch With Fog Lamps*5016709AA by the Jeep Specialists | Morris 4x4 Center |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Tail light wiring question | mcgarys2007 | YJ Technical Forum | 0 | 10-19-2007 01:54 PM |
| Light Bar Wiring Question. Help! | jmbrewe2 | TJ Technical Forum | 12 | 08-04-2007 10:27 AM |
| Fog light wiring question for my LJ | yj_ryn | TJ Technical Forum | 3 | 06-17-2006 01:58 PM |
| KC light wiring question | Jeep14636 | TJ Technical Forum | 6 | 08-26-2004 07:56 PM |
| Light Bar Wiring Question | Nighthawk | TJ Technical Forum | 5 | 06-24-2002 06:31 AM |
The time now is 11:42 AM.
Jeep®, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
