01 Wrangler blower only works on low speed - JeepForum.com
post #1 of 4 Old 06-28-2009, 01:56 PM Thread Starter
dab77
I have my nieces Wrangler with numerous problems. Most are simple service issues such as brakes and tune-up.The blower motor is a different matter. It only blows on low.The relay is good, the resistor is ok and as far as I can tell the control head is working.I don't know where to go next. I don't have a wiring diagram. Any help will be greatly appreciated
dab77 is offline
post #2 of 4 Old 06-28-2009, 03:35 PM
JBTJ
I would think that the resistor pack is bad. It is a very common problem with TJ's. Another problem is with the fan speed switch. These are the only diagrams I have. Hopefully this will help you.
JBTJ is offline
post #3 of 4 Old 06-28-2009, 04:34 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
TheBoogieman is offline
post #4 of 4 Old 07-02-2009, 09:06 AM Thread Starter
dab77
Thanks
Thanks for the help. Blower switch took care of the problem
dab77 is offline
AC Blower only works in HIGH ?!? ITCS_USN_RET TJ Wrangler Technical Forum 7 09-21-2009 11:02 AM
Blower only works on Hi BomberJeep TJ Wrangler Technical Forum 5 11-23-2008 05:05 PM
A/c Blower Only Works On High bodee21 TJ Wrangler Technical Forum 22 08-17-2007 09:10 PM
Blower only works on high? jeephreak TJ Wrangler Technical Forum 17 02-03-2007 09:16 AM
Fan blower only works on 3, not 1, 2 & 4 fergyfer TJ Wrangler Technical Forum 8 07-04-2005 09:28 AM
