Quantcast 01 ton TJ - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > 01 ton TJ
Old 08-28-2008, 11:10 AM   #91
jimaug87
I just read all seven pages. Excellent build. I can't wait to see the pics of you breaking things in on the trail.
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline   Reply With Quote
Old 08-28-2008, 03:19 PM   #92
Jkanly
Originally Posted by 2005BlackRubi View Post
yo awesome build wish i could get tube fenders and like the tail lights
Speaking of which, where can I get some of those taillights? They look pure insanity
"Energizer Bunny arrested, charged with battery" - Jay Leno
l _____
/l
,[____],
l---L –0lllllll0-
()_)-()_)--o-)_)
~ Do it right or don't do it at all ~
Jkanly is offline   Reply With Quote
Old 08-28-2008, 04:46 PM   #93
cmoore
www.northridge4x4.com
LiteDots link
Talk to David. He's been my big brother so to speak in the formulation of this build.
cmoore is offline   Reply With Quote
Old 09-01-2008, 12:09 AM   #94
cmoore
So the high steer arms from Solid don't come drilled. I spent a fair amount of time on the phone with Lance at PSC (thanks Lance) and he told me to drill the arms out at 8" in front of the kingpin. So that's what I did.
These arms are stout, you'll want one of these. Even still it's a PITA as the arms were still tough to drill through.
I used a ton of this to keep from killing my bit.
Here's how the engine bay panned out. I had to move the stock coolant reservoir for the hydro reservoir.
I found a small replacement coolant reservoir at the local parts store and it tucked in perfect on the passenger side.
The FIPK (I don't recommend them fwiw) actually still fit despite the coilover crossbar. I did need to cut the back side of the box out a little though.
Front 60 together. I finished the ram mount and the service access for the diff. With the bar out, there's plenty of room to mess with whatever.
Had a little scare on Saturday. Went to put put the cover and fill the diff up when I noticed a screw missing from the ARB. I freaked out and called Daivd at Northridge as well as the ARB rep. Turns out that missing screw is on purpose (it only gets one for c-clip 60s).
Old 09-01-2008, 07:33 AM   #95
cmoore
Made some major progress the past few days. My rig is finally drivable. :rock:
still needs a few things but it runs and drives.
to do list:
straps & bumps (there's a local shop owner here who volunteered his lift on Tuesday to let me stretch it out for clearances)
vent lines & arb lines
zip tie everything
get a new battery
*I will probably need to adjust the steering links a little bit. I don't see any binding but the up angle is a tad more than I had planned on (especially on the short passenger side).
Old 09-01-2008, 09:11 AM   #96
Savvy
Savvy Off Road
Savvy's Avatar
to do list:
zip tie everything
get a new battery
I'm asking cause I want to learn. The ram attahces to the link that goes to the steering arms. It look like in the pic above the link will pivot? What stops them from pivoting? I see hiems on both ends. I'm missing something and the light has not come on!
Nice build!
I'm only doing ram assist in my build but I like learning new stuff.
Email me for the fastest response: gman@savvyoffroad.com
Follow us on Facebook FACEBOOK.COM/SAVVYOFFROAD
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
PM MrBlaine for Black Magic Brakes!
http://www.savvyoffroad.com
2006 LJ Unlimited Black Hole
2005 LJ Test Mule
2003 TJ Project Unrolled
2003 TJ Project Click Here
Savvy is offline   Reply With Quote
Old 09-01-2008, 09:27 AM   #97
spyder6
Just violated my Parole
spyder6's Avatar
yeah im a bit confused myself, it looks like hte steering system can manipulate itself
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 09-01-2008, 01:44 PM   #98
alex71
No he doesnt need a tie-rod with the double ended ram. It is the only thing needed in the steering but those angles on the arms dont look right.
2001 jeep wrangler sport / Waggy 44 /FORD 8.8. lockright/ 4.88 / 3/2'' lift,Stretched to 100.5/ Warn x8000i / 35in BF KM2's / AtoZ rockers, cage,/ Poison spyder crusher corners.
Vote for TJOFTY!
http://www.jeepforum.com/forum/f9/tj-year-contest-2010-vote-now-contest-has-started-1140918/index9.html
alex71 is offline   Reply With Quote
Old 09-01-2008, 07:50 PM   #99
cmoore
The angles front to rear are fine. When the tires are straight you can have some forward angle. It's when the tires are at full lock that you want to have the ram and linkage straight. Mine do that but the up angle isnt perfect. Ideally the links would not have any vertical angle. Lance at PSC told me some was fine but I'll ask him on Tuesday what he thinks (in the mean time the steering drives better than it ever did before with the stock geometry). Also, it would be more ideal to have the ram centered on the axle. I didnt want to be as tall as it would take to fit the ram dead center of the axle. As a result, my passenger side needed a very short link which increases the angle and appearance.
The ram is straight, but you're right it does look tilted in the pic.
Here's a few pics for steering in case I didnt explain it well.
My rig has roughly about 4" suspension lift (+ or -) over stock and a 1" body lift (with the coilovers in the lowest position--I can go a few inches taller if I decide I need to). As it is set up right now I have just under 5" upward wheel travel. I haven't compared to a stock rig exactly but my friend's TJ on 4.5" RE lift and 1" BL on 33" BFGs is 3.5" shorter than mine on 39.5's.
I'm surprised no one commented on the tires. I must have been tired when I was putting them on as I put the fronts on reversed.
Old 09-01-2008, 09:54 PM   #100
Twitchy
I've learned a lot from this build and so wish i had your building skill sets. Very nice job and look forward to the finished for good version of this thread, LOL. I've thinking about going with Solid Axle Industries under my rig, just can't decide whether to go with King pin or ball joint.
My store of choice....NATIONAL 4 WHEEL DRIVE; CALGARY, ALBERTA
RCD 6" Long Arm, Procomp Xterrain 35x12.5, DC-1 Black 16x10, Champion 10,000lbs winch, PIAA lighting, H4 Headlights, Magnaflow muffler, Viking Soft Top, Tuffy Consoles, Boston Acoustic audio, Hurst short throw, Trailjammer system, Air Raid CAI
my armor thread: http://www.jeepforum.com/forum/f9/360-degrees-gen-right-tj-armor-594083/
Twitchy is offline   Reply With Quote
Old 09-01-2008, 10:41 PM   #101
BozoWise
Great build, I'm slowly catching up with you but your time frame was impressive.
My 1 ton TJ build project "Evil Monkey": [url]http://www.jeepforum.com/forum/showthread.php?t=423989[/url]
BozoWise is offline   Reply With Quote
Old 09-01-2008, 10:53 PM   #102
spyder6
spyder6's Avatar
neither did i, it didnt even phase me. im used to seeing people run competition claws backwards and it just didnt click
USAF
Blue Crush Build
Really?
Old 09-02-2008, 08:19 AM   #103
jason m
they bite better backwards, that how i run mine now. we did a friends rubicon a few years back with a solid 60 front and those front C's are bassed on dana 70 C's. all i can is wow there huge. nice build and great write up, jason.
1993 YJ 4.0 60 Front, Rear steer 60, bolth spooled, 5.38's, 700r/241 39.5 iroks and beating it like it owes me money.
jason m is offline   Reply With Quote
Old 09-03-2008, 03:12 PM   #104
cmoore
Originally Posted by thedirt View Post
Cmoore, roughly how much lift is that over stock. I know it's not exact, but I'm just curious.
here's a good comparison: I found a bone stock 06 tj to park next to at the office.
Old 09-03-2008, 03:40 PM   #105
jim_bert
WOW....
2001 Yellow Sport, I6, Dana 44 3.73 gears, 31x10.5 procomp AT on cragar soft 8s, silverstar headlights, black headlight bezels, raingler full netting system, raingler roll bar handles, EK motorsport maglite holder, Tuffy door lockers, Tuffy glovebox, stepshield door entry guards, 130w Halogen KC Daylighters on windhield mounts, kenwood kvt-819dvd, 5.25" front speaker conversion, door switch defeat, U-Pol Raptor liner, Dynomax Super Turbo Cat-Back Exhaust, Iggee seat covers, SAVVY LED Taillights.
jim_bert is offline   Reply With Quote
Glock Forum
