zero oil pressure - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > zero oil pressure
ZONE 4.25" combo lift for TJ available at Rockridge4wNew Hours at RUFFSTUFF!Enjoy 5% off in April 2000-2006 Jeep Wrangler Ignition Coi
Unread 04-04-2015, 05:18 PM   #1
Jcarney1200
1975 CJ5
zero oil pressure
So I just recently replaced my oil pan gasket and oil pump gasket. .. added oil today and have zero oil pressure. Question is do I have to prime my oil pump our let the engine run till it gets suction. I let the engine run for 20 secs and had no pressure. Help please
Jcarney1200 is offline   Reply With Quote Quick reply to this message
Unread 04-04-2015, 05:23 PM   #2
Jcarney1200
1975 CJ5
By the way its a amc 304 V8 1975 cj 5
Unread 04-04-2015, 05:38 PM   #3
FrontierGander
1973 CJ5
I'd prime it. We did it on our 73 258 I6 and it has great oil pressure. Why chance it?
FrontierGander is offline   Reply With Quote Quick reply to this message
Unread 04-04-2015, 05:54 PM   #4
Jcarney1200
1975 CJ5
How do I do that...
Unread 04-04-2015, 07:12 PM   #5
sojourner55
Prime the oil by removing the distributor running a cut off screw driver with a drill in the oil pump spindle which the lower distributor shaft mates to.
sojourner55 is offline   Reply With Quote Quick reply to this message
Unread 04-04-2015, 08:02 PM   #6
Jcarney1200
1975 CJ5
I was reading that you can also fill the pump and oil filter up with oil and do it that way has anyone tried that?
Unread 04-04-2015, 11:08 PM   #7
jeepdaddy2000
1971 CJ5
You should always fill the filter when you do an oil change.
Prime the pump by packing it with some Vaseline. This will provide some suction to pick up the oil from the pan.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 04-05-2015, 10:39 AM   #8
Jcarney1200
1975 CJ5
To all... the vasoline method is a thing of beauty! Packed it this morning torqued everything down cranked it up and have full oil pressure. Thanks for all the good advise and now I can add this to my knowledge base
