your thoughts on lucas oil stabilizer - JeepForum.com
post #1 of 64 Old 06-24-2013, 05:30 AM Thread Starter
Stegs
quick question
bought a 1978 jeep cj5 with the 258
jeep sat in a storage unit for a while, so i ran less that a quarter of marvel mystery oil in the motor oil and poured the rest in the gas tank
I ran the jeep for maybe 60-70 miles with the MMO in the oil
now its time for a oil change again
Im going again with 10w30 in high mileage with a napa gold filter
my question is should i replace 1 quart of oil with lucas oil stabilizer to help boost oil pressure in my old motor
it runs good, got some very slight motor noise, but then again so does my 99 cherokee ....
your thought on doing this? good idea in older motors? i read that its OK for older engines that dont run alot of RPM...like a jeep
or should i just change oil viscosity? something other than 10w30? Id still prefer to run high mileage
Stegs is offline
post #2 of 64 Old 06-24-2013, 05:47 AM
gmakra
I have never been a proponent of the magic pill. Things like Slick 50, Motor Medic, Sea Foam Fitz Fuel Catalysts never produced any major results. So to answer your question if if you want to run Lucas as additive to help your oil do its job then your ok. If you think Lucas will boost oil pressure and take up the slack in the worn machined surfaces of your engine then I think you will be disappointed.
gmakra is offline
post #3 of 64 Old 06-24-2013, 07:06 AM
steve1973
1973 CJ5
No. Run the viscosity your owners manual says to, mine says 5-20W and thats what it runs. You dont need high mileage. The gold oil filter will boost your oil pressure.
steve1973 is offline
post #4 of 64 Old 06-24-2013, 07:25 AM Thread Starter
Stegs
do you have the same motor as me? the 258?
maybe thats why my oil pressure is 20 pounds...im running the wrong viscosity
I assumed it was 10w30 like everything else....
*i will note i live in michigan, but the jeep is only driven during the summer months...and I have no owners manual..
reading others forums, i think i should be 15w40 at minimum...
Stegs is offline
post #5 of 64 Old 06-24-2013, 07:35 AM
The_Blacksmith
1993 XJ Cherokee
Lucas will boost your oil pressure, it is a proven fact. Lucas products are gold. If you ever had a bad slipping auto tranny that you needed a little more life out of, you know what I'm talking about.
Its not gonna take you up a ton of oil pressure, but it helps.
Thanks Chris!
The_Blacksmith is offline
post #6 of 64 Old 06-24-2013, 08:20 AM
robs7
1983 CJ7
I add it in every part of my Jeep. Motor, manual transmission, transfer case and differentials. I only run mine in the summer so a little thicker oil doesn't hurt. It won't make old parts new by any means but I feel like it makes old parts last. Kind of like taking medications when you get old I guess. Just my two cents. Rob.
robs7 is offline
post #7 of 64 Old 06-24-2013, 08:45 AM Thread Starter
Stegs
kinda what im thinking
I just went to napa and picked up 5 quarts of 10w40 HM and 1 quart of lucas and a napa gold oil filter...that should boost oil pressure more than 20lbs going down the road....(as far as original gauge is concerned)
Stegs is offline
post #8 of 64 Old 06-24-2013, 10:45 AM
lucdog
lucdog's Avatar
1980 CJ5
I'd be interested in knowing this as well.
Attachment 641208
My 1978 owners manual calls for straight 30w down to a given Temperature, IIRC around 30* , lower than that it was 20w.
To bump up a couple years my '05 TJ calls for 10w-30 with the 4.0L. My '94 4.0L YJ was the same.
I doubt any Recommendation from the OEM on oil Viscosity was ever 5w-20 for a CJ, with a 258 or a 304. The 4cyl. Could be different.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #9 of 64 Old 06-24-2013, 11:18 AM
cj5huntingrig
1974 CJ5
Originally Posted by Stegs View Post
quick question
Go ahead and do an oil change w regular oil but substitute 1 quart of cheap tranny fluid. It will degunk your engine. Run for a few hundred miles and change again like normal
1974 CJ5 all stock except for Rocky Road SOA
Completely for hunting - not for show or rock climbing
cj5huntingrig is offline
post #10 of 64 Old 06-24-2013, 11:24 AM Thread Starter
Stegs
i ran marvel mystery oil in it for the last 75 miles or so (maybe 100)
It thinned my oil out of course, and developed a leak from somewhere
Im hoping its because of the thin oil, now putting 10w40 and 1 quart lucas to stop the leak and build oil pressure
*please dont be the rear main seal leaking* please, pretty please*
Stegs is offline
post #11 of 64 Old 06-24-2013, 11:27 AM
hotrod351
1955 M-38
i use syn oil, i read that its better for anything that isnt going to be driven that much and it last a lot longer. lucas is a good product. if you think you need it then try it. all the aftermarket stuff out there isnt bad, some does work.
hotrod351 is offline
post #12 of 64 Old 06-24-2013, 11:35 AM
82JeepCJ7
1982 CJ7
I never put any additives in the oil or coolant. They should not need them.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #13 of 64 Old 06-24-2013, 11:37 AM
nixer600
My personal experience as well.
Sent from AutoGuide.com Free App
nixer600 is offline
post #14 of 64 Old 06-24-2013, 11:54 AM
cj5huntingrig
1974 CJ5
These engines leak like sieves anyways. You may want to do yourself a favor and just don't worry about the leak until it gets bad. Then go ahead and replace the RMS and oil pan gasket with the Felpro one piece it's worth the time and investment
post #15 of 64 Old 06-24-2013, 12:16 PM Thread Starter
Stegs
it didnt leak until i did the MMO
thinking it got thin and thats what is leaking
oh well...
I will see if thicker oil help any, or i will do the RMS this winter
Stegs is offline
