#16 | |
I installed a Painless factory harness kit in my '84 Cali-emissions CJ7. The install was anything BUT painless since I had to integrate the engine control computer and all the emissions stuff. Spent several days just on the engine bay as I basically had to chase each original wire, make my own diagram (my FSM did not have the factory wiring diagrams) and then figure out where it would fit best in the Painless harness. The maxi fuse takes the place of the fusible link wires in the original harness, so you need to do one or the other for safety reasons. I also remember the Painless diagrams being a bit confusing when it came to wiring in the Ford ignition module, then again, I was dealing with the computer there as well. Oh, if I remember correctly, the directions were reversed for wiring up the electronic oil pressure gauge on the dash, but it sounds like you don't have one. Good luck!
Russ 1984 CJ7 “When you're swervin' on life's highway, you're runnin' someone off the road." -- Robert Earl Keen Military Jeepers Click Here! |
#17 |
ok update and few more questions and one bonehead move corrected.
First off thanks for all the helpful replies. I figured out the 4 wires this was my bonehead bit ![]() it was the wiring that goes to the ignition switch ![]() Now for the update, I had a family friend over this weekend he looked it over and gave me the green light for what I had wired in the engine and the head and tail lights. I have some new questions. headlight switch Im lost with out a diagram ![]() can anyone tell me what wire goes where if the picture is good enough? Turn signals again without having any reference I have no way of connecting ![]() how do I check these? which one is the power source so I can maybe hook them up by trial and error. speedometer cluster ![]() there is a dbl wire on the turn signals lights is this for front and back or is this for ground wires? also on the fuel gauge I had 3 wires connected to the right side post and one to the left side post. Im assuming the third post is a ground Any advise would be much appreciated Thanks Jeff K |
#18 | |
ET48 1986 CJ-7 LAREDO, 4.2L, 5 speed, 3.31 Gears, D30, D44, 2.5" ProComp lift, 3" BL, 33" TSLs. 1998 TJ SAHARA, 4.0L, 5 speed, 4.11 Gears, D30 (Aussie Locked), Ford 8.8, 4.5" Custom LA, XRC8, AA SYE, TW DS, ZJ tie-rod, Full-Traction front adj. track bar, 35" KM1s. |
#19 | |
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
Man I just put a Centech harness in mine and it went in really easily and sweet. All the lines were marked and the book had excellent drawings for the speedo cluster and other dash parts. It was really 'painless'. Did the kit not come with a headlight switch plug? That sucks the big one. John Strenk has the pinout for the switch.
Mike 86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10) |
#20 |
I beginning to think I did not have everything for the painless wiring kit. the kit came with the Jeep when I bought it and it was in two different boxes along with the body lift kit the whole thing looked like it had been stitting out in the weather for a yr or two. So maybe I'm missing some of the diagrams.
I do have anohther question do I have to use the maxifuse on this model yr Jeep? Its a 74 with a 258 engine? No power sterring no AC Last edited by Liv2bowhunt; 06-23-2009 at 04:15 PM.. |
#21 |
Painless makes two kits for this era Jeep, a pre-terminated one which has all of the factory ends including the headlight switch, and new speedo bulbs and sockets, stuff like that, and a non-terminated one which would require you to splice into your factory plugs. Looks like you have the second one. Did you save any of your old plugs?
1981 Scrambler that is very under construction, but moving along. |
#22 | |||
What was I thinking
![]() and another: ![]() I have to check on this again. But it's lunch time. Quote:
![]() Not the same as many others. If you can send me a nice picture of the front and back I'll illuminate it and use it for future reference. Quote:
![]() Check again, The TS should only have one wire unless the bulb is in the wrong place. Usually those with two wires were for the brake warning light. There may even be a Alternator warning light in there someplace. Show me a picture of the front of your speedo and we will figure this out. in the mean time here is a nice copy of a 74-75 schematic: http://civilianjeep.info/Strenk/Electrical/74-75A.jpg http://civilianjeep.info/Strenk/Electrical/74-75B.jpg |
#23 | |
This is why Im lost for making the connections to everything under the dash. I was trying to save the turn signal clip and after taking a closer look at it last night Im not real sure I want to leave that clip on. Ill just cut it off and splice the new wires in. Jeff K |
#24 |
John S
Thank you very much for the diagrams!!!!! ![]() Those will help me greatly. If you don't mind me asking where can I find those on the net so in the future I can just pull them up on my laptop? As for the speedo cluster it is very possible I have the bulbs in the wrong place as my son was the one who removed them with out paying attenttion to where they came out of. This thing has been a learning lesson for him and me both Me learning to breath deep and explain in great detail to my son what I want or am trying to do and him learning how a car works. He's 14 and thinking this is going to be his ride for school in a cpl of yrs![]() I will post a picture of the front side after I get home tonight. Again thank you for the diagrams!!!!!!! Jeff K |
#25 |
One other thing I just thought of. I did not see any wires coming off the master cylinder for the brake lights
I now this may sound like a dumb question to many of you but I really don’t have a clue as to how the brake light gets triggered when I hit the brake peddle![]() Thank you Clueless!!!!!!! ![]() Jeff K Last edited by Liv2bowhunt; 06-23-2009 at 02:18 PM.. |
#26 |
What was I thinking
It's on the brake pedal. Look at ares 8A on the link in my post for the schematic.
Look on your brake pedal up near the pivot point. If you want to save the pictures just right click on the picture and save them to your computer. |
#27 |
1974 CJ5 wiring diagram
You can download a wiring diagram with a table of connections for the 1974 CJ5 from here:
http://vectorid.com/jeep/1974_jeep_cj5_wiring_diagram.pdf It's from the technical service manual. |
#28 |
For anyone doing future wiring jobs...Painless is very expensive, go to Home of EZ Wiring, they have harness sets with great instructions for around $150-$170 pending how many fuses you want, plus every 6 inches on the wire they tell you where the wire goes, so when playing with the wires down the road you can look at the wire and indentify what your looking at.
#29 | |
#30 |
ET48: Sell me your front seats!!! lol
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
