your out of here - JeepForum.com
post #1 of 7 Old 08-21-2013, 05:06 AM Thread Starter
toprope1
your out of here
84 cj7 258 how many vaccuum lines can i remove? need spark adv. and pcv. i hope thats all.
toprope1 is offline
post #2 of 7 Old 08-21-2013, 07:52 AM
WindKnot
1977 CJ7
If you have power brakes, don't remove that one!
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #3 of 7 Old 08-21-2013, 08:51 AM
superj
i ran my yj (87, so its a square headlight cj) using the minimal lines you can run. i have the power brake, the distributor and 4x4 on one line, and the small line from the intake to the firewall. i am not sure if your will have that last one though.
google cj vacuum diagrams and you can find a good one with minimum lines to set yours up from.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #4 of 7 Old 08-21-2013, 09:11 AM
supersport126
Did you nutter bypass? If not google it.
supersport126 is offline
post #5 of 7 Old 08-21-2013, 09:24 AM
jimbos76cj
My 88 is nuttered and only has the PVC and distributor vacuum lines on the carb.. the bowoer brakes go to a port on the bottm of the intake.
88 YJ 35's 8.8 rear, family style roll bar, ax-15 external slave conversion, Custom double D fab dash 4" of lift taurus fan, Head light wiring upgrade, MSD 6al, JB conversions SYE, 258 with RV cam, Long tube headers, Borla exhaust. 1"mm, Auto meter gauges.
jimbos76cj is offline
post #6 of 7 Old 08-21-2013, 10:21 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Keep the Evap Can hooked up, or your next thread will be about obnoxious gas smells...
Rick
Cutlass327 is offline
post #7 of 7 Old 08-21-2013, 10:39 AM
LumpyGrits
Do you ever have to SMOG it?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
