You know you drive a CJ when..... - Page 3 - JeepForum.com
post #31 of 2612 Old 11-28-2008, 09:13 PM
1984CJ
1984CJ's Avatar
When you carry a flashlight to check the gauges at night.
When you go to a parts store and have to give them three different vehicles that you need parts from to fit your Jeep
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #32 of 2612 Old 11-28-2008, 09:18 PM
gojeepgo
1981 CJ7
When you have the auto parts guys home phone number.....
Or when he tells you to just come around the counter and look it up yourself
gojeepgo is offline
post #33 of 2612 Old 11-28-2008, 09:24 PM
danheit
danheit's Avatar
1979 CJ7
When you have scheduled "preventative measure" tetanus shots each year....
I NEED A SINGLE 15X8 MICKEY THOMPSON OR SIMILAR ALUMINUM BULLET HOLE WHEEL!!!!
Build Thread: 1979 CJ7
danheit is offline
post #34 of 2612 Old 11-28-2008, 09:33 PM
Lifesgoodhere
thats me
A Jeeper for life
Lifesgoodhere is offline
post #35 of 2612 Old 11-28-2008, 09:33 PM
only in a jeep cj
.....your friends tell you to NOT park on the clean driveway when you visit them.
....its 40 degrees outside and could rain, but you still want to drive your topless Jeep.
....you own special tools just for working on your Jeep......(Model 20 hub puller, ALL torx sizes, uhhh, a welder...)
.....you see a wrecked Jeep and start thinking of what parts you could use or interchange from it.
....you'd rather wear old torn clothes and shoes with holes in them so you can spend that money on Jeep upgrades.
......none of your other friends have cars with a secert kill switch.
....at a traffic light, you look around and see others staring at you from their little econobox cars with the look of wishing they enjoyed driving as much as you do!
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #36 of 2612 Old 11-28-2008, 09:39 PM
gojeepgo
1981 CJ7
...You open you hood and have to explain what that thing is to the on-lookers.....repeat after me...car-bor-a-tor...
gojeepgo is offline
post #37 of 2612 Old 11-28-2008, 09:41 PM
slacker92104
slacker92104's Avatar
When you buy it for $1600 and then spend over $5000 in upgrades.
'81 CJ5, efi 302, AX-15 5 spd, On Board Air, wrangler spring conversion, Astro van Hydro Brakes.
Soon: Custom cut Dana 44 front, wide trac solid axle amc 20 rear, SOA,
slacker92104 is offline
post #38 of 2612 Old 11-28-2008, 10:01 PM
Jzilla
when you dont have to have a key to crank it.....
Jzilla is offline
post #39 of 2612 Old 11-28-2008, 10:02 PM
79cj7stone
1979 CJ7
when you can thump a gauge to make it work
79cj7stone is offline
post #40 of 2612 Old 11-28-2008, 10:11 PM
chadcarter
1983 CJ7
That is so classic! (and true!)
1983 Jeep CJ-7, AMC 360 swap, TF999, AMC 20 w/ 4.10s Mosers & Detroit, Dana 30 4.10s Open. 4" BDS with 1" Daystar BL & 1" Shackle lift. 35x12.50x15 General Grabber M/T. Corner & Rocker protection by Sniper Fab, with Bumpers by GroundPounder Fab.
chadcarter is offline
post #41 of 2612 Old 11-28-2008, 10:59 PM
bluwtrsurfr
bluwtrsurfr's Avatar
LoL this is definatly true...though I think ive covered the 5000 just in new tires and rims, a lift and a winch....
...when you say your just gona fix one or two things and the next thing you know your in a full frame off restoration cause you found the po just used bondo on the body to hide rust holes
Will
81 Jeep CJ5 4" lift, 33" Mickey Thompson Baja Claw tires.
bluwtrsurfr is offline
post #42 of 2612 Old 11-28-2008, 11:36 PM
dkg4244
1983 CJ8
when you know that every drive you take is an adventure in itself.
when you've called on at least one or more friends at a time to help lift something out of it.
when you purposely drive more on the right side of the road to let the uptight people pass you.
dkg4244 is offline
post #43 of 2612 Old 11-28-2008, 11:41 PM
Ones&Zeros
When you evaluate every part and piece of scrap that you run across, irregardless of the manufacturer or what its previous purpose was, just to see if it has any value to you whatsoever. You're always thinking, "If I change this and this, I can adapt it to make it do this........."
Ones&Zeros is offline
post #44 of 2612 Old 11-29-2008, 12:02 AM
fredrok
........and it's now worth $1650......
If you don't have time to do it right, how will you ever find time to do it again?
fredrok is offline
post #45 of 2612 Old 11-29-2008, 03:58 AM
turnabout
1974 CJ5
you keep an extra Jeep on hand for parts........
Originally Posted by BESRK View Post
turnabout.. where you at in Tidewater?
Eddie-
I'm in Williamsburg. I've been meaning to stop by your shop but haven't made the time........Mike from NC stopped by and picked parts off of my 74 donor on his way to NN to pick up a bumper with a friend. Sounds like you're in the Lee Hall / Denbigh area?
The two best off-road vehicles in the world -- the Jeep CJ and rental cars.
turnabout is offline
Drive CJ5 or CJ7? RODDOR Jeep CJ Forum 51 01-28-2013 02:02 AM
Drive shaft redflame6 Jeep CJ Forum 11 03-31-2009 07:15 PM
New Drive Shaft HELP Joe_CJ5 Jeep CJ Forum 2 01-12-2009 09:55 PM
I got to drive!!! bulldogger Jeep CJ Forum 9 09-14-2007 12:14 PM
First drive bigflatblack Jeep CJ Forum 17 06-11-2007 02:07 PM
