You know you drive a CJ when..... - Page 156 - JeepForum.com
post #2326 of 2612 Old 08-08-2013, 03:31 PM
outdoorguy86
1983 CJ7
Originally Posted by CJ7KAHUNA View Post
You've just put on your 14th new starter and you hear the dreaded gnashing, metal grinding sound of your starter drive gear exploding when you try to start your Jeep.........AGAIN!
I think something else is wrong....
Colorado Jeep Club Member #2086
/l , [____],
l---L---OlllllllO-
()_) ()_)=@=)_)
outdoorguy86 is offline
post #2327 of 2612 Old 08-08-2013, 03:45 PM
titomars
1981 CJ7
I think it might be time for a new ring gear.
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #2328 of 2612 Old 08-08-2013, 05:37 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
ring gear or is it being shimmed correctly?
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2329 of 2612 Old 08-08-2013, 07:03 PM
CJ7KAHUNA
Actually when I originally had this issue I did replace the ring gear. Its about a year old. The number of 14 was a comedic exaggeration - was just remembering a recent post where someone was going through the dreaded starter issue and had replaced the starter several times.
I had this issue a little over a year ago - after several new starters and a ring gear my mech friend finally made up a shim and got the starter to function without self destructing. The only thing that was not replaced was the bell housing. Recently I had a motor failure and my mech friend is doing the swap out at his home shop. He calls me up last night to tell me it got the swap done and the motor started and mentioned that the starter made the dreaded gnashing metal to metal sound it did when the problem started originally. This is with a different block, bellhousing, alignment dowels were checked prior to install and a practically brand new starter. I am not sure it will develop into the same issue but I am scared that it will.
This starter thing is one problem that many have and few fine the same root cause. Its the very worst part of owning a CJ IMO.....everything else is gravy.
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
post #2330 of 2612 Old 08-08-2013, 07:19 PM
larock
1983 CJ7
Your friend pops the clutch and you and up replacing a rear axle, rear driveshaft and 2 u joints
larock is offline
post #2331 of 2612 Old 08-08-2013, 07:35 PM
Jack718
1972 CJ5
Ha, just did this today. I have a full floating rear and blew the hub apart.
Jack718 is offline
post #2332 of 2612 Old 08-08-2013, 08:45 PM
titomars
1981 CJ7
AMC uses Ford starters there should be no shims involved. In all my years as a mechanic and with Ford I have never heard of or seen a case where shimming a starter was needed. If the starter is chewing teeth maybe it is your source of starters. I only have ever used Ford Reman or Napa starters on my Fords and AMCs. I have never had a problem.
Now if you're missing block alignment dowels or missing the plate between the block and bell housing either will give you a short lived starter.
titomars is offline
post #2333 of 2612 Old 08-09-2013, 09:25 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I'm thinking the block plate is missing....
Rick
Cutlass327 is offline
post #2334 of 2612 Old 08-09-2013, 09:52 AM
billybooster2
1983 CJ8
Flywheel cover? Im following along.. What block plate?
billybooster2 is offline
post #2335 of 2612 Old 08-09-2013, 10:51 AM
knowlwk@snowhill.com
1980 CJ7
You hang a quick left turn coming off the highway and out of the corner of your eye... watch your cell phone, which you left on the passenger seat, go flying out the passenger doorway and tumble to a stop in the median.
or
You honestly don't know how to answer "What year is your jeep?" (or simply don't have the time to explain the truth)
or
You're afraid to actually drive your jeep, because on the last trip... everything ran great, sounded great, stopped great, shifted great, nothing fell off... is was a perfect trip... and you want to remember her that way!
'80 CJ7, 258 W/Autojuicer, MC 2100, TFI, SummitRacing CDI, MORE SRS, Moser 1-pc, YJ tub on 1" body lift, YJ family cage.
knowlwk@snowhill.com is offline
post #2336 of 2612 Old 08-09-2013, 11:15 AM
holliewood61
1981 CJ7
I tell people its titled as an 81, but remember that johnny cash song about the caddillac? Well its kinda like that.
08 WK bone stock
00 WJ daily driver
99 TJ mostly stock 97 TJ cheap jeep
81 CJ7 very little stock
60 CJ5 tore down
holliewood61 is offline
post #2337 of 2612 Old 08-09-2013, 11:35 AM
I6CJ7
or
or
Oh man... I've lost count of the times my cell phone has done that in my CJ taking a hard turn! Skates across the highway like a hockey puck!
One time i even had my half soft doors on and i took a turn.. It slid across hit the door.. And because the damn smartphone is so thin, slipped right down between where the door seal against the tub sill..
I6CJ7 is offline
post #2338 of 2612 Old 08-09-2013, 12:48 PM
titomars
1981 CJ7
that's kind of where my mind is going.
titomars is offline
post #2339 of 2612 Old 08-09-2013, 03:38 PM
EgulAye
1980 CJ5
Block plate? Hmmm
2012 JK
Do you wave at night when they can't see you?
EgulAye is offline
post #2340 of 2612 Old 08-09-2013, 04:27 PM
skizriz
1978 CJ7
You honestly don't know how to answer "What year is your jeep?" (or simply don't have the time to explain the truth)!
" the title says '78" is always my response.
Sent from my HTC One SV using JeepForum
skizriz is offline
Drive CJ5 or CJ7? RODDOR Jeep CJ Forum 51 01-28-2013 02:02 AM
Drive shaft redflame6 Jeep CJ Forum 11 03-31-2009 07:15 PM
New Drive Shaft HELP Joe_CJ5 Jeep CJ Forum 2 01-12-2009 09:55 PM
I got to drive!!! bulldogger Jeep CJ Forum 9 09-14-2007 12:14 PM
First drive bigflatblack Jeep CJ Forum 17 06-11-2007 02:07 PM
