You know you drive a CJ when..... - Page 155 - JeepForum.com
post #2311 of 2612 Old 08-05-2013, 04:06 AM
2Xtreme
2Xtreme's Avatar
1979 CJ7
You know you drive a CJ when every damn thing you do leads to something else to fix...
2Xtreme is offline
post #2312 of 2612 Old 08-05-2013, 07:59 AM
WindKnot
1977 CJ7
Originally Posted by I6CJ7 View Post
The CJ may not be flat, but its snag free!
My sisters TJ's skidplate has lips on the front and back that curl down... They are just screaming to snag rocks, trees, ledges and whatever else to get hung on.
I'd like to clock my dana 300 flat but i read you have to cut the floorpan! No thanks... Not on my antique! I'll just tuck the skid closer to the drive train
Not quite...
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #2313 of 2612 Old 08-05-2013, 03:40 PM
zeros52
1976 CJ5
When your happy because you think replacing the steering shaft is going to be quick and simple. Then find out you have to drop the gearbox because the shaft is welded for some reason. Then find ouy that your new "HD" shaft matches up with the gearbox but is to big to fit in the steering column....well gues i know why it was welded.
zeros52 is offline
post #2314 of 2612 Old 08-05-2013, 04:23 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
Originally Posted by WindKnot View Post
When your "project" is rated 2 wrenches and 3 hours in the parts catalogue and actually takes all day and requires the purchase of a new bench grinder just to complete it!
Oh well, you can never have too many tools!
LOL we rate projects by beers, as in how many to get it done.
more helpers= more beer
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2315 of 2612 Old 08-05-2013, 04:24 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
tip the table and the ball rolls to the other corner... know all about that. One project begets 4 more...
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2316 of 2612 Old 08-05-2013, 04:34 PM
dison001
Only 4? You sir must have 1 very nice Jeep.
dison001 is offline
post #2317 of 2612 Old 08-05-2013, 06:05 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
haha its all very exponential: one simple project = 4 more and each of those = 4 each. Discovering and upgrading PO boo boos, or swap in new bump stops and uh oh... new crack in frame, or running a replacement air line and ugh... critical wires chaffing on some metal edge. or in the process of something simple, like general maintenance discover a broken spring leaf or in replacing that, 'might as well' address a related issue. its a true rabbits hole. The shop whiteboard was full and we're nearing the end of some stuff, others being discovered...and I've had the 8 for 12 years...
a mix of repairs and upgrades smashing into the reality of just address that one issue or the collateral problems. I'm very methodical and somewhat of a perfectionist with my vehicles, so it always takes longer to do it right than if a shop were to hack it in.
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2318 of 2612 Old 08-05-2013, 06:30 PM
Jeeper44mag
1978 CJ7
EXACTLY.
Luis
Black '05 LJ, soft top, ~4" lift, 42rle, 3.73, 35"x12.5" AT's, Tampa FL area
Jeeper44mag is offline
post #2319 of 2612 Old 08-05-2013, 07:24 PM
JMcDonaldKnives
1980 CJ7
Whats funny is that my 89 YJ is acting like a CJ, lol. Wiring problems (if I hit the wiper switch they wired up then sometimes it wont work and the radio shuts off, not to mention the gauge lights and AC still dont work due to electrical problems), leaks (fixed the engine leaks and now the trans has leaks), and I'm hearing rattles from time to time and I just don't feel like trying to find them and fix them cause to me its just character, lol. Not to mention I need to replace the front calipers so that I can actually bleed the brakes and at some point I need to inspect the rear brakes to see what kind of condition they are in. On top of that I need to realign the wiper arms so that it actually cleans the proper areas. I need to finish pulling out the AC system and fix the electrical. Oh ya, the previous owner decided to use a big *** bolt in place of the wiper switch/turn signal lever because the old one broke off and it doesnt click when I hit it for a right hand turn but still turns on the turn signal but does work fine for a left turn.
Director of Texas Jeeps Corpus Christi Chapter
My Build Threads
1980 CJ7 4.2L T177 D300 D30 AMC20 (under construction)
1989 YJ 4.2L T177 NP231 D30 D35 Pro Comp 3" lift 32/1150/15 BFG AT
JMcDonaldKnives is offline
post #2320 of 2612 Old 08-06-2013, 09:49 PM
zeros52
1976 CJ5
When you are considering getting a 2nd vehicle for when you go 2 collage/technical school for 2 years and have to drive roughly 700 a month. But instead of considering getting a truck like alot of people recommend you look at another jeep instead. (albeit a tj but still a Jeep.)
zeros52 is offline
post #2321 of 2612 Old 08-06-2013, 11:07 PM
RARECJ8
RARECJ8's Avatar
1981 CJ8
how about during every trail ride...there...wait for it... a new mystery rattle...
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #2322 of 2612 Old 08-07-2013, 03:14 AM
Captainak
1982 CJ7
When it's "built" but you can't stop....
1982 CJ7, AMC 401, Dana 60 & 14 Bolt
http://jeepspace.jeepforum.com/Captainak
https://plus.google.com/photos/116451153412037001676/albums/5857883655447386049
Captainak is offline
post #2323 of 2612 Old 08-07-2013, 07:33 PM
boojeep
1979 CJ5
When you have to have the wife help you place the new nuts at the top inside of the cowl above the defroster duct in the middle.Now I need to fish out the 2 nuts that fell in. 2 steps forward and 3 sideways or something. That was yesterday, today was full on ignore mode. Tomorrow?
boojeep is offline
post #2324 of 2612 Old 08-08-2013, 05:10 AM
Captainak
1982 CJ7
Drove into the sunset!
post #2325 of 2612 Old 08-08-2013, 05:21 AM
CJ7KAHUNA
You've just put on your 14th new starter and you hear the dreaded gnashing, metal grinding sound of your starter drive gear exploding when you try to start your Jeep.........AGAIN!
My childhood was typical. Summers in Rangoon, luge lessons. In the spring we'd make meat helmets.
When I was insolent, I was placed in a burlap bag and beaten with reeds. Pretty standard, really.
CJ7KAHUNA is offline
Drive CJ5 or CJ7? RODDOR Jeep CJ Forum 51 01-28-2013 02:02 AM
Drive shaft redflame6 Jeep CJ Forum 11 03-31-2009 07:15 PM
New Drive Shaft HELP Joe_CJ5 Jeep CJ Forum 2 01-12-2009 09:55 PM
I got to drive!!! bulldogger Jeep CJ Forum 9 09-14-2007 12:14 PM
First drive bigflatblack Jeep CJ Forum 17 06-11-2007 02:07 PM
