You know the sound the giant ants made in "THEM"? - JeepForum.com
post #1 of 11 Old 12-04-2013, 11:43 PM Thread Starter
wsmutch
That's the noise my jeep, a 1986 CJ-7, makes driving in wet conditions. At first I thought it was a squealing fan belt but it isn't. It only happens in wet conditions, tonight we had snow followed by freezing rain then rain. The roads were 6 inches of very wet slush on top of ice. My jeep would squeal as I released the clutch, and put it under load. When I reapplied the clutch it would quiet down or go away. It did it once before but after sitting for 8 hour while I worked it went away. That day was wet earlier and dried up before the end of my shift. It's very embarrassing driving down the road with my jeep screaming like a banshee. Any thoughts?
wsmutch is offline
post #2 of 11 Old 12-05-2013, 04:13 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Perhaps an oil-glazed flywheel or clutch disk.
Does your RMS leak?
Matt
Matt1981CJ7 is offline
post #3 of 11 Old 12-05-2013, 08:37 AM
WindKnot
1977 CJ7
Is the flywheel inspection plate missing?
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #4 of 11 Old 12-05-2013, 08:48 AM
Blakescj7
x2 on both. i believe it could be because the clutch friction plates are glazed and the flywheel needs turned and the moisture making it slip a bit under load
Blakescj7 is offline
post #5 of 11 Old 12-05-2013, 10:36 AM
WindKnot
1977 CJ7
Accidently placed in another thread?
Originally Posted by wsmutch View Post
That really sucks because I replaced my clutch and flywheel this summer. I had the oil pan gasket, main seal, and oil pump replaced 3 weeks ago. Does this mean a new clutch again?
It is a possibility. Look for leaks. did YOU replace the clutch & flywheel, or had it done?
WindKnot is offline
post #6 of 11 Old 12-05-2013, 11:39 AM
texasdave
texasdave's Avatar
1980 CJ7
Could be a bad throw out bearing.
texasdave is offline
post #7 of 11 Old 12-05-2013, 05:41 PM
LumpyGrits
Bet it's a dried up pilot bearing.
BTDT......
When is the last time you oiled/greased the linkage?
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #8 of 11 Old 12-05-2013, 09:18 PM Thread Starter
wsmutch
No, I didn't do it myself. I like to think I'm a pretty good locomotive engineer, and I can do some simple mechanical things but if anyone can screw up a job like that, I will. I have a mechanic that works on my jeep as a side job and he seems to do a pretty good job. Also, I drove it to work today. It ran like a top and not a single squeak. It was sunny today, and the temperature well below zero.
wsmutch is offline
post #9 of 11 Old 12-05-2013, 09:29 PM
LumpyGrits
As a Engineer, you should know of the old say'n of 'oil'n about'
LG
post #10 of 11 Old 12-05-2013, 10:07 PM
86cj74.2L
86cj74.2L's Avatar
Originally Posted by texasdave
could be a bad throw out bearing.
+1
86cj74.2L is offline
post #11 of 11 Old 12-06-2013, 09:24 AM Thread Starter
wsmutch
To quote one of my favorite movies, "I only ride 'em man, I don't know what makes 'em work. "
wsmutch is offline
