you guys are working wonders today......here's a steering query. - JeepForum.com
post #1 of 9 Old 11-30-2011, 10:26 AM Thread Starter
Foxybingo
1980 CJ5
Everyone has been great helping me with ball joint issues but here's a new challenge. My CJ5 is right hand drive and steers with a track rod end that attaches to the main track rod. This is not a home made effort.....however I want to do a tie for flip and thanks to Keith for great advice. When I flip the track rod....the kink and hole for the tie bar to go into is not the best......question is can I put a straight tie rod from steering knuckle to steering knuckle and a new tie bar from steering knuckle to steering box......as per later CJs. I only ask because the steering knuckle with 2 holes for track rod ends and the steering box are on the same side of the jeep.....will this cause issues when the suspension flexed?.....hope this makes sense.
Foxybingo is offline
post #2 of 9 Old 11-30-2011, 10:30 AM Thread Starter
Foxybingo
1980 CJ5
Current set up.
post #3 of 9 Old 11-30-2011, 10:32 AM Thread Starter
Foxybingo
1980 CJ5
Proposed knuckle to attach tie rod.....before tie rod flip.
post #4 of 9 Old 11-30-2011, 10:45 AM
scoutboater
1974 CJ5
If I understand you correctly, you are wanting to tie your steering box (on the right side) to the knuckle on the same (right) side, correct?
If I'm thinking correctly, that will make the tie rod from the steering box to the knuckle very short. Because it will be short, it will have to flex a lot on both ends when the axle flexes up and down. Unless I'm way off the reservation, I think this would reak havok on your steering when you are flexing.
Think about it this way: your tie rod is a set length (for obvious reasons). When the right side of the axle droops, the tie rod must droop also. The steering box is mounted to the frame, so that end cannot move. The other end is tied to the knuckle, which can. So, when the axle droops, the tie rod will pull on the knuckle, making the front wheels turn left. Its not as much of a problem with a left-hand jeep, because that tie rod runs the width of the vehicle, and the "droop steer" is not a problem.
Now, if you are hooking the steering box (on the right side) to the knuckle on the left side, ignore everything I've said, it should work just like the factory setups you mentioned.
scoutboater is offline
post #5 of 9 Old 11-30-2011, 10:53 AM Thread Starter
Foxybingo
1980 CJ5
How you first read it is correct. The knuckle on the left side only has one hole. I know it would affect steering when flexing, just wondered if anyone knew how dramatically?
post #6 of 9 Old 11-30-2011, 12:52 PM
CSP
It would be very dramatic. You want the drag link (bar from steering box to knuckle) to be as close to parallel as possible to the tie rod (knuckle to knuckle).
That would be a huge angle to go from the box to the right side knuckle. I highly doubt that you would have enough angularity built into the drag link end to even make the connection.
CSP is offline
post #7 of 9 Old 11-30-2011, 03:05 PM
scoutboater
1974 CJ5
I agree with CSP. It would be difficult to even make the connection.
post #8 of 9 Old 11-30-2011, 04:05 PM
JeepHammer
Running On Empty...
1973 CJ5
This is no big deal, unless I'm missing something I can't see in the pictures...
Give anyone any ideas? this isn't the first time links have been fabricated and stacked...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #9 of 9 Old 11-30-2011, 06:58 PM
keith460
Jeep. There's Only One
keith460's Avatar
Yes, as JeepHammer has pointed out, that can be done. Stacking the Drag Link on top since you cannot flip that type of Tie Rod, that you have, around as it would face rearward. The hard part would be finding a Rod End Bearing with a male-threaded shank that had a threaded stud long enough to accept a another Rod End Bearing without the stud. Must fit tight also and here in the United States, Rod End Bearings or Heim Joints as they are sometimes refereed to, are usually not allowed to be used as steering components unless you have special titling for the vehicle, say a Hot Rod for instance.
1984 CJ-7 Renegade
keith460 is offline
