York On board air - JeepForum.com
post #1 of 13 Old 07-28-2013, 06:14 PM Thread Starter
BlueRubiconrich
York On board air
Ive had my York on board air for years. I think I killed it,so I swapped in a differant York .Hit the switch nothing? What do I do?
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #2 of 13 Old 07-28-2013, 06:45 PM
skizriz
1978 CJ7
Are you getting power to the clutch??
Did you test the clutch with a known power source to make sure it works??
skizriz is online now
post #3 of 13 Old 07-28-2013, 06:47 PM Thread Starter
BlueRubiconrich
yes,I'm not hearing the click.
post #4 of 13 Old 07-28-2013, 06:55 PM
MoC
If u have 12v and no click then either its not grounded or the clutch is bad.
Is the compressor new?
MoC is offline
post #5 of 13 Old 07-28-2013, 06:57 PM
skizriz
1978 CJ7
post #6 of 13 Old 07-28-2013, 07:02 PM Thread Starter
BlueRubiconrich
well it has to be grounded it's bolted to the engine block.
No it's used.How do I remove the clutch?
post #7 of 13 Old 07-28-2013, 07:15 PM
MoC
IIRC it requires a special tool. Lots of articles out there about it. Try google searching
MoC is offline
post #8 of 13 Old 07-28-2013, 07:21 PM Thread Starter
BlueRubiconrich
I must have that tool a 5/8" 3" bolt LOL I removed the small bolt allready.
post #9 of 13 Old 07-28-2013, 08:12 PM
MoC
Get it off?
MoC is offline
post #10 of 13 Old 07-28-2013, 11:10 PM
82JeepCJ7
1982 CJ7
Just thread a bolt into the center and use it to pull the pulley off. Its as simple as it can get.
Once you get the pulley and outer assembly off, you will see the electro-magnet part of the clutch held on with 4 small bolts. It simply unbolts.
This is the bearing number for the clutch assembly if you choose to replace it.
While it's apart, you can determine what CFM York you have by the end of the shaft.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #11 of 13 Old 07-29-2013, 02:10 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
This might help too:
http://www.jedi.com/obiwan/jeep/york_id.html
It is interesting that the web addy is in Star Wars honor, as I am watching Ep5 right now...
And just because it is bolted to the engine, doesn't mean it has a perfect ground. Paint, Never-Sieze, etc,. can hinder good grounds.
Rick
Cutlass327 is offline
post #12 of 13 Old 08-02-2013, 06:18 PM Thread Starter
BlueRubiconrich
I had not tried to get the pully off yet. found out that there is a S on the top of the Yorks for suction. The new York has the S on the outside not the inside so I had to swap the hoses. The new compressor does not have the click sound when I hit the power but it does work.
post #13 of 13 Old 08-02-2013, 07:01 PM
LumpyGrits
Run a jumper from the battery POS(+) to the wire on the comp. You should hear the clutch engage.
Your gnd is the engine block
LG
LumpyGrits is offline
