YJ Tub on CJ7 - JeepForum.com
post #1 of 3 Old 03-16-2003, 08:03 AM Thread Starter
4bangercj7
YJ Tub on CJ7
SITUATION: Complete 89 YJ tub, windsheild frame, heating ducts, tailgate, and dash and harness. Seatbelts, everything basicly, cept seat/brackets/top/doors.
Replace my CJ tub with this one, re-use my fenders/hood/grill. I know that two body mounts need to be relocated. Also, I can not use my CJ windsheild frame with the newer ducts, do not line up correct ? Also, can not use my cj's dash without moifications for the ducts as well correct ? Also, I would have to get a wranger gas since filler neck is on the opposite side. Would one fit in the cj's spot ? Would my CJ's seat brackets mount up to exiting holes ? or would I have to create new ones ?
The big question is with the fuse block. Alot different then my 86 ?
Connector wise ? If it was, I would get the connectors from the wranglers harness and splice them into my current 4 bangers connectors if that needed to be done.
What you all think ? Its this or fiberglass tub, body replacment options. If I went this route, I would be saving bout $700 then ordering a tub, having it shipped, etc.
Ideas/comments/pitfalls etc.
Thanks
4bangercj7 is offline
post #2 of 3 Old 03-16-2003, 10:44 AM
ninjajeep
ninjajeep's Avatar
Maybe you should talk to CJeep. He has a YJ tub on a CJ frame..heres the post:
YJ tub swap
'01 TJ 60th Anniv. Ed.
"6 cylinders of gut wrenching torque"
ninjajeep is offline
post #3 of 3 Old 03-17-2003, 10:27 AM
Brock
Brock's Avatar
Do a search on the forums. There has been a lot of discussion on the tub swap. I am planning one myself. Good luck. Also, go to google.com and search for YJ tub swap. There are about six or seven really good and detailed websites about the conversion.
Brock is offline
