YJ suspension lift kit on a CJ7? - JeepForum.com
post #1 of 7 Old 07-25-2009, 08:49 PM Thread Starter
westtexascj7
Do any of you all know if a yj suspension lift would work on a CJ7?
westtexascj7 is offline
post #2 of 7 Old 07-25-2009, 08:56 PM
jooper84
Front CJ springs are 2" wide. YJ springs are 2.5". You'll either need to put a pair of rear CJ shackle hangers on the front or run adapter shackles. Everything else in the kit should work - assuming it comes with plates (can't reuse the stock CJ plates on the front).
jooper84 is offline
post #3 of 7 Old 07-25-2009, 09:03 PM
OlivergreenCJ7
yeah run the CJ rear shackle hangers in the front and move it forward about an inch. Do a search it's been talked about. The front bolt for the hanger becomes the back one and you just redrill the front hole. You might be able to use your spring plates if you drill them out, but It might better to just find new YJ ones Ubolt skid plates.
OlivergreenCJ7 is offline
post #4 of 7 Old 07-25-2009, 09:06 PM Thread Starter
westtexascj7
Do you think that Yj springs would make for a better ride?
post #5 of 7 Old 07-25-2009, 09:08 PM
otis68
1978 CJ7
If you are getting a kit the pitman arm is different, and shocks are different. I got the parts i needed from rough country but not in kit form. Well worth the effort the ride and flex are both greatly improved. I got spring plates from Rocky road.
otis68 is offline
post #6 of 7 Old 07-25-2009, 09:56 PM
jooper84
It'd be a good time to flip the TREs to the top of the knuckles - then you can run the stock CJ pitman arm. The kit with the reamer is about the cost of a CJ drop arm anyway and you don't lose any turning radius like you do with a drop arm.
jooper84 is offline
post #7 of 7 Old 07-26-2009, 09:51 AM
jeepskate
It's a fairly common swap (the springs, nothing else). Search around this or any other Jeep forum and you'll find plenty of info on the swap.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
Suspension Lift Help Jbrizzle Jeep CJ Forum 4 01-19-2009 07:20 AM
suspension lift 78GoldenEagle Jeep CJ Forum 13 05-08-2008 02:31 PM
Would someone please explain the difference between a suspension lift and a body lift Giff Jeep CJ Forum 5 09-20-2007 03:49 AM
Body lift vs. Suspension Lift jmreagan Jeep CJ Forum 4 02-10-2006 02:49 PM
CJ7 suspension lift guachinango Jeep CJ Forum 5 02-03-2005 03:12 PM
