YJ Springs for my CJ - JeepForum.com
post #1 of 12 Old 07-19-2014, 09:45 PM Thread Starter
JeffreyCharles
1976 CJ5
A thing that's been bugging me for awhile is the fact that my rear sags (shut up, shut up, shut up!). Parked next to all sorts of nifty old Jeeps today it was obvious enough that even my wife could see it (I said shut up!).
So, it looks like perhaps a YJ conversion is in order. Being one step away from the poorhouse these days I figure this will need to be a staged conversion. So I'm thinking I'll start with the rear and do the front later on. That avoids the whole "do it once and do it right" issue. I will do it right, but in stages - starting with the rear.
So, I figure I'll spend the majority of my budget on things like the shackle hangers (Crabtree) and shackles (Ground Pounder). Should I maybe even consider a lift? I don't ever plan to run anything larger than 33's and I have 31's now which seem just fine for my daily driving and work around the barn. So a lift might not be useful.
The question is, what do you all think I should expect to pay for a set of YJ springs. I'm assuming they'll be used. I see a set of rears on eBay for about $125 and have no idea if that's reasonable or not. Maybe an afternoon at a pick-n-pull with a couple jacks and tools will produce springs for less. Problem around here is that pick-n-pulls are not what they were when I built cars in high school more than 30 years ago. Selection is limited. Can't wander the junk yards like we used to be able to do. Insurance and lawsuits I suppose...
I've read the various conversion threads which are very informative and the project doesn't daunt me. Scoping budget now rather than how to do it.
Whatcha think?
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #2 of 12 Old 07-19-2014, 10:45 PM
dg6772
I think if you decide a lift is in order,then doing it in stages is out.
I've "heard" good and bad on yj springs. Softer ride,but weaker spring and can sag sooner; but firsthand knowledge of this I do not have.
A (short term) solution could be to re-arch springs and add a leaf. A friend did this. Very inexpensive; but seemed to be a little stiff. This could suffice until you've saved enough for a proper conversion or lift.
Dave in Muskegon using JeepForum
dg6772 is offline
post #3 of 12 Old 07-20-2014, 05:20 AM
travisintally
1982 CJ7
Jeff
I am one mailman delivery away from starting my conversion and if you can hold out a week or so I am going to document parts, vendors and cost along with progress and pics on my 82 CJ-7. I am using a 2.5" Ole Man Emu spring set.
travisintally is offline
post #4 of 12 Old 07-20-2014, 08:15 AM Thread Starter
JeffreyCharles
1976 CJ5
Dave, I looked into the add-a-leaf approach and it seemed to introduce a level of stiffness that many of the folks who'd done it found uncomfortable. But it's certainly an option. Good point about not lifting both ends at the same time. I worded things poorly - I'd do the springs in stages while collecting the parts for a mild lift and do that at the end.
Travis, I'll certainly be happy to read along. I'm not moving quite that quickly on things so your experience and documentation will be very helpful.
Jeffrey Charles
post #5 of 12 Old 07-20-2014, 02:45 PM
Jim1611
Jim1611's Avatar
Since you guys are going to change springs and related hardware get your can of penetrating spray and start soaking every bolt right now. Do that a few times between now and tear down and maybe you won't break those spring hanger bolts off in the frame.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #6 of 12 Old 07-20-2014, 05:15 PM
Viencent
1982 CJ7
Something else to consider. With the yj springs you will get about a 2in lift. My 82 has yj springs and clears 33's
Viencent is offline
post #7 of 12 Old 07-20-2014, 05:20 PM
dg6772
Huh?! Didn't no that.
dg6772 is offline
post #8 of 12 Old 07-20-2014, 06:56 PM
Viencent
1982 CJ7
ya here are a pic with the 33's so you can see the clearance I did trim the back a little to match the flares, with myslefand the wife upfront and my 15 year old daughter ive had no rub problems
Viencent is offline
post #9 of 12 Old 07-20-2014, 08:41 PM
loyalpoke
Viecent, are your springs under or over the axle?
loyalpoke is offline
post #10 of 12 Old 07-20-2014, 08:53 PM Thread Starter
JeffreyCharles
1976 CJ5
Jim, one thing I've been incredibly lucky about so far is that I've not had any seized or rusted bolts to deal with in the various projects I've done. The PPO (previous, previous owner) knew at least something when he did the rebuild back in the 90's and that's not an issue I face. The PO didn't know much at all except how to throw money at problems - and who am I to complain about that?
(of course, getting the %$^#*@ drums over the brake shoes in back is another matter...I really want disc brakes back there)
Jeffrey Charles
post #11 of 12 Old 07-21-2014, 06:14 PM
Viencent
1982 CJ7
Under
Viencent is offline
post #12 of 12 Old 07-22-2014, 12:05 AM
loyalpoke
Thanks
