YJ Spring conversion - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > YJ Spring conversion
Ring & Pinion's, Lockers, 4340 Axles, Install Kits, BaRockridge 4WD IS Taking Zone Offroad Suspension Lift Kits Engo winches available at www.rockridge4wd.com! Free shipp
Unread 04-07-2012, 12:00 PM   #1
RecklessCJ
1972 CJ5
Just picked up a set of YJ springs, shackles, spring plates, and u bolts for $80. Best deal I've found yet! Curious if anyone knows or has a set 2.5 in hangers and perches?
Any pointers / how to tips for doing this on an intermediate would be great!
Thanks
RecklessCJ is offline   Reply With Quote
Unread 04-07-2012, 03:34 PM   #2
NoNative
NoNative's Avatar
I bought Jim's yj hangers and they rock. Use the google search function at the top left of the page and you should be able to find him pretty easy. He's a forum member and makes them.
Taylor
1986 CJ-7 Laredo, 258, AX15, AC Dana 30/44, Ox Lockers, Howell TBI, DUI, 4.5" RE YJ Springs, 1.25" BL, clocked & twin-sticked Dana 300 with Lomax 4-1, 4.10s, 33s, PB, 8000# winch, YJ Roll Bar, Factory 20 gallon tank.
1984 CJ-7 Renegade, 258, T4, AC, Howell TBI, DUI, 2.5" OME YJ Springs, 3.53, 31s, PB, Warn bumpers & 8000# winch, Factory 20 gallon tank
1984 CJ-7 Renegade, 258, Auto, AC, 3.31s, PB, Factory 20 gallon tank, Bone stock except for 31s
NoNative is offline   Reply With Quote
Unread 04-07-2012, 05:16 PM   #3
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
Don't forget to move the front shackle bracket forward about an inch (you'll have to remove a frame rivet), since the YJ fronts are longer.
You'll also have to correct the caster. Most either cut and reinstall the spring perches, or use shims.
Good luck,
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 04-08-2012, 04:07 PM   #4
dan-cj7
If you buy an aftermarket shackle hanger, like the MORE ones I did you don't have to remove the rivet in the crossmember. They have a hole that fits over it. I don't know about the crabtree ones though.
1984 CJ7 - Under construction
4.6L stroker with MPI & AX15 with D300
OME 2.5" YJ springs
http://www.jeepforum.com/forum/f8/dans-downunder-84-cj7-build-1299387/
dan-cj7 is offline   Reply With Quote
Unread 04-09-2012, 04:05 PM   #5
Chewtoy
1976 CJ5
Matt
Maybe I missed something but I don't understand why you would have to correct the castor by changing to YJ from CJ springs. I get it if the OP were lifting at the same time, but OEM to OEM all it is going to do is move the front axle forward by 1/2", but it doesn't change the pinion angle by any noticable measurement.
Help me understand please?
With a great Jeep comes an empty wallet.
Chewtoy is offline   Reply With Quote
