#1 | |
YJ spring conv.
What do you guys think about this...
http://www.rocky-road.com/wranglerconversion.html I want to change to YJ springs for a little better ride and this seemed like a good solution to fact that the springs are a little longer. Is there something better or a better place to buy from? Thanks
1979 CJ7 258 T150 Dana 20 |
#2 |
anyone?!? I need to purchase something soon/ asap
#3 |
I have the YJ springs on my CJ. I used a conversion kit from BDS part #124021. It went on great. I also used BDS suspension lift kit #408h. Here is there catalog: http://www.bds-suspension.com/BDSLibrary/catalog/Jeep07v2.pdf
1984 CJ7 Renegade - 258 4.2L, 5 Speed, 2" BDS YJ Springs with BDS CJ Conversion Kit, Weber 34 DGEC Carburetor, Aluminum Valve Cover, 73 Chevy Blower Motor, Bestop Supertop, Pro Comp XTreme Alloy 1079 Wheels, 33" x 12.5" x 15" BF Goodrich AT KO Tires, Holley Fuel Pressure Regulator and Gauge, Flowmaster 40 Series with Universal Catalytic Converter and 2 1/2" Pipe and still going..... [url]http://www.jeepforum.com/wiki/index.php/1984[/url] [B]There is a $10,000.00 CASH REWARD for anyone with information leading to the arrest and conviction of the person(s) that killed my cousin Blake Dickus and his stepmother Chynna Dickus on July 24th, 2006. Please contact the Franklin, Indiana Police Department at [url]http://www.franklin-in.gov/police/[/url] or contact America's Most Wanted at [url]http://www.amw.com/fugitives/case.cfm?id=51938[/url][/B] |
#4 |
GROUND POUNDER
Don't know as you need a "kit" to do the YJ conversion. Just use a CJ rear shackle hanger up front. Drill out the crossmember rivet and it becomes the new forward bolt hole for the front shackle mount.
I've never run stock YJ springs on a CJ before but I think you may lose lift since they're "flatter" springs (stock). Might want to do at least a small lift? As for prices... that website's spring prices look decent.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s.. Lower 2 Guardrail Down Schoolbus Slickrock Tellico Save Crozet More Crozet |
#5 |
thanks guys, the cj rear hanger are cheaper which is good and I think I am going to get an old man emu 2.5 lift
#6 |
Well VaCJ79, I have a PaCJ79 and let me tell you:
If what you are looking for is a better ride from your CJ, you are doing one of the best things! A long time ago I was probably among the first to convert to OME Wrangler springs. Here is what it took me to do it: 1. Rear CJ shackle/spring hangers up front. (with rivet drilled out, etc., etc. to get the extra inch in length that you need. 2. Front YJ spring plates. 3. Rear CJ, or better yet, a good after-market pair of YJ shackles. By all means, don't buy a fancy kit, they make me sick. Jeeps are so easy to make/adapt things for, you don't need to buy a "kit" for every single thing that you want to do to your CJ. Oh, and OME is the best ride, hands down! You're headed in the right direction! Good Luck.
Sold the BMW to afford Jeep parts. |
#7 |
Like Besrk & BigTorque said, there's cheaper wayd to go about doing it than buying a kit. emember this: Most of the stuff that you see aftermarket kits for CJ's has already been homebrewed for cheaper. This conversion has been covered on every Jeep forum for many years now and a little searching will turn up multiple ways of accomplishing it.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers. '83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff. http://www.jeepskate.net |
#8 |
I bought the "kit" because I wanted all new parts and it was more convenient to get everything at one time in one package rather than order everything separate. I was able to sell a lot of other parts that I had and turn that money into buying a complete kit to make life a little simpler. If you can afford to purchase the kit, I would go for it. I liked getting all new parts in one kit instead of trying to piece everything together. The other guys do have very good points as well. You can save some money by piecing it out. This is just my .02. Good luck with your project!
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
