-   -   YJ power brake booster swap too big? (http://www.jeepforum.com/forum/f8/yj-power-brake-booster-swap-too-big-1848265/)
drespecki 12-01-2013 10:21 PM
YJ power brake booster swap too big? Pics?
Running a 258 with the motorcraft carb and am thinking of doing the YJ master/booster swap but might have read somewhere that there are clearance issues with the motorcraft carb?
Anyone running this or try this setup? Pictures?
skizriz 12-02-2013 02:33 AM
I am. The loops of line going to the MC are a tight fit as they move to the carb side. The air cleaner is also a tight fit, but thhere are a few different options for clearance.
Sent from my HTC One SV using JeepForum
tjeep1 12-02-2013 05:40 AM
not to bother you both but im just put the booster on my tub and running a 2150 carb any pointers would be great skiz as far as problems you dealt with thanks in advance
skizriz 12-02-2013 06:05 AM
Other than the rod from the pedal to the booster being too short, Its pretty straight forward.
drespecki 12-02-2013 07:28 AM
Any pics to be had? Can one take small sections of line, pre-bend and add them on to go around to the other side while leaving the original lines intact?
skizriz 12-02-2013 10:10 AM
I just moved my original lines around to the other side,and used the proper adapters to fit the MC. Worked Fine.
Eventually i made new lines and eliminated the adapters though.
tjeep1 12-03-2013 12:14 PM
skiz did you coil the lines when you made them, im thinking of no coils because it is not going to be off road that often. i know coils are for body roll what is your opinion on straight lines from mc to proportioning valve thanks
drespecki 12-03-2013 04:31 PM
Pics anyone?
CrankyD 12-03-2013 06:00 PM
I made a hybrid booster MC combo for mine using the CJ master cylinder and the YJ booster. I have a 258 with MC2100 and the only clearance issue I have is the rod to the grill shell. I swapped grill shells and the tab on this one isn't in the same place. I guess there are some for power brakes and some for those without.
http://www.jeepforum.com/forum/f8/fr...-guts-1213015/
The time now is 07:44 AM.
