YJ needs some CJ help - JeepForum.com
 1Likes
  • 1 Post By Matt1981CJ7
post #1 of 8 Old 08-18-2017, 10:02 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
Please see the attached photo, I have been searching on Google and the forum for help on this.
I have two missing bolts on my 90YJ . all I keep finding is help with the power steering bracket for the serpentine belt and mine has the v-belt just like its older brother the CJ.
My son said I need to ask CJ people.
I searched power steering pump bracket for CJ and it is the same as mine.
All I need is the size bolts that are circled.
SOME PEOPLE ARE LIKE SLINKIES - NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN THEY'RE PUSHED DOWN THE STAIRS.
JMAC90YJ is offline
post #2 of 8 Old 08-18-2017, 10:08 AM
keith460
Jeep. There's Only One
keith460's Avatar
I'm pretty sure they are 3/8-16 x 3/4"L Indented Hex Head bolts.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 8 Old 08-18-2017, 10:45 AM
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
In situations like this, I usually just rummage thru my spare bolts bin to determine the correct size and thread count. Once I figure that out, the length is usually pretty easy to determine.
Matt
pedal2themetai likes this.
Matt1981CJ7 is offline
post #4 of 8 Old 08-18-2017, 10:50 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
I tried that route and believe it or not did not have one bolt that would work,
I think I will have to clean the threads with a Tap.
JMAC90YJ is offline
post #5 of 8 Old 08-18-2017, 11:10 AM
cJAY904
I had an issue with one of those bolts on my CJ. the best solution is what you just said, use the tap and you will be good to go. I used a bottoming Tap to be sure the new bolt would sit tight.
cJAY904 is offline
post #6 of 8 Old 08-18-2017, 11:23 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
Thanks alot.
JMAC90YJ is offline
post #7 of 8 Old 08-19-2017, 12:20 AM
STJP
In this application it may be best to not use a cutting tap but a thread chaser/restorer to determine thread pitch.
https://www.summitracing.com/parts/pow-pow351675
I find this tool very useful in SAE and Metric................
https://www.lowes.com/pd/IRWIN-Metri...Gauge/50146288
in combination with a thread gauge like these.
https://stainlesstown.com/tools/nut-bolt-gauges
I got mine at Fastenal.
JS
STJP is offline
post #8 of 8 Old 08-21-2017, 07:04 AM Thread Starter
JMAC90YJ
JMAC90YJ's Avatar
Thanks,
I forgot, We have a set of the thread gauges from when my son went to Penn college, and I have the plastic thing I got it from work.
JMAC90YJ is offline
