YJ leaf springs restored to install into my CJ5 - JeepForum.com
post #1 of 47 Old 03-13-2013, 12:05 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Hi guys,
I recently bought a set of used YJ leaf springs to swap into my CJ5, to soften the ride somewhat. I've read a lot of info on the subject, but most of the swaps are with aftermarket kits.
Here is my step-by-step efforts to restore the springs, and hopefully improve their performance, followed by a question that I have.
Here they are, as I bought them. I started taking them apart...
I had them sand blasted. My plan is to paint the leaves with POR 15, so getting them 100% rust free was not important.
I bought a roll of 2.5" wide teflon leaf spring liner material. I wanted to install this in between each leaf...
I cut all the pieces...
Then, the ends were contoured with a cutting wheel...
The center holes were marked, then punched out...
Making sure they fit...
Put them aside, for now...
Ready to paint...
First coat...
Then, applied a second coat.
They dried so glossy, that I temporarily bolted them together, and sprayed a coat of Krylon satin finish on the topside, the sides, and the bottom ends, just to dull them down, a little...
Final assembly...the liners and new spring pack bolts installed. At this point the alignment clips had to be bent back around the leafs. This was not a fun job. Good thing I have a hydraulic shop press.
A closeup of the liners...
The bolts will be cut to their final length later on.
Here's where my question comes in...
I've read that if you buy an aftermarket lift kit, you don't have to move the front shackle brackets forward 1", because the kit allows for that.
I decided to use my current front shackle hanger brackets, so I bought RE conversion shackles. These shackles have a 5" center hole spacing. My current shackles have 4" center hole spacing. Because the new shackles are longer, will that allow me to install the leaf springs without moving the shackle hanger brackets forward?
Here are a few pics of all that stuff...
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #2 of 47 Old 03-13-2013, 12:17 PM
stamp32
Because the YJ springs are an inch longer, I would treat the install like a YJ lift kit conversion ie. Old Man Emu and remove the hanger and install an inch forward. This will allow more movement of the shackle. If you leave the hanger where it is, the bottom of the shackle will be protruding outward about an inch and not vertical thus negating the benefit of the longer lead springs added flex and travel.
Chris
stamp32 is offline
post #3 of 47 Old 03-13-2013, 12:21 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Thanks Chris...that sounds like good logic!
Rich
rixcj is offline
post #4 of 47 Old 03-13-2013, 01:03 PM
TIPPEDITOVER
At the Mall
TIPPEDITOVER's Avatar
1978 CJ5
Dang that looked like alot of work. Nice job!
TIPPEDITOVER is offline
post #5 of 47 Old 03-13-2013, 11:53 PM Thread Starter
rixcj
rixcj's Avatar
1979 CJ5
Thanks! Yeah...I get carried away, sometimes..
Rich
rixcj is offline
post #6 of 47 Old 03-14-2013, 10:38 AM
jeepwhore
Chris
Shackles are not supposed to be completely vertical.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #7 of 47 Old 03-14-2013, 12:46 PM
TIPPEDITOVER
At the Mall
1978 CJ5
Shackle supposed to be at 90 degrees, or IOW perpendicular to a line drawn between eye bolts. Any more angle results in stiffer spring rate, any less gives less spring rate. You put it there it's in the middle of the range.
post #8 of 47 Old 03-15-2013, 08:45 AM
CSP
No, the shackles should not be at 90 to the spring eyes. Somewhere in the 50-60 range gives a good mix of compression and extension.
Why in the world would more angle result in a stiffer spring rate? Spring rate only changes as the spring flexes and the change is negligable.
CSP is offline
post #9 of 47 Old 03-15-2013, 11:28 AM
TIPPEDITOVER
At the Mall
1978 CJ5
I should have said a good place to start is 90 degrees. Where are you getting your information?
Here's a good write up on it. Go to the bottom to read about shackle mechanics. 5 second google search
http://www.quadratec.com/jeep_knowle...article-93.htm
post #10 of 47 Old 03-15-2013, 11:40 AM
TIPPEDITOVER
At the Mall
1978 CJ5
Oh and as to why it would change spring rate. It's explained in that link. I'll admit it's a bit convoluted, but it's better than I can explain.
post #11 of 47 Old 03-15-2013, 11:53 AM
TIPPEDITOVER
At the Mall
1978 CJ5
Another link for you to read. Better than just saying your wrong and I'm right.
http://forum.ih8mud.com/60-series-wa...ring-rate.html
post #12 of 47 Old 03-15-2013, 12:29 PM
CSP
Experience is what tells me that. I know who wrote that article, and it's one person's opinion which I have publicly disagreed with on more than one point. There's a lot more going on when a spring flexes than just spring rate.
Do as you wish, mine rides great.
CSP is offline
post #13 of 47 Old 03-15-2013, 12:45 PM
TIPPEDITOVER
At the Mall
1978 CJ5
Oh I will do as I wish with or without your approval all knowing king csp. I will also gladly lend a hand to others along the way, without a condescending attitude.
post #14 of 47 Old 03-15-2013, 12:48 PM
TIPPEDITOVER
At the Mall
1978 CJ5
sorry to hijack your thread rixcj
post #15 of 47 Old 03-15-2013, 01:50 PM
CSP
Really TIPPEDITOVER? Care to make any other judgement out of context while you're at it? Are you another one of those guys that makes it personal when someone disagrees with you?
I'm just amazed at how people can read an article "published" on the internet and take it as gospel.
I know, you can't put anything on the internet if it isn't true.
Done with my portion of this hijack.
CSP is offline
