Yj Heater Box Swap... - JeepForum.com
post #1 of 5 Old 10-23-2009, 07:50 AM Thread Starter
poppatello
I posted a thread looking for new Cj heater box parts and someone posted on using a Yj box. I asked and looked but couldn't find a write up on a Yj heater swap. Has anyone done this and is there a write up?
In a world full of copy cats, be an original...
Paved Roads
A Fine Example of Needless Government Spending
Originally Posted by berserker View Post
Sometimes it a good idea to pull a vacuum hose before the wife rides in it--you can tell her you need a new ____ and once you get your new ____ you can reconnect the hose. :)
84 Cj 7 w/ 4-Banger, 4.5" BDS lift, 1/2 Trans Drop, Twin Stick, 32" Tire, Front Aussie Locker, No Sound System Yet, No Armor, Warn 8274 Not Installed, Webber Carb Upgrade, Luckycheese Ing. Upgrade...
poppatello is offline
post #2 of 5 Old 10-23-2009, 08:04 AM
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I had posted a while ago about a mutt setup of some YJ parts inside the CJ case... you need the CJ case back plate to fit up nicely in the CJ and if you did a YJ tub swap, then the YJ back plate would fit nicely. they are essentially the same.
the issue I had was that the bolts snapped off when removing the back plates.
Bottom shows the 2 different assemblies
certifiablejeep.com - Project "Free Jeep" a.k.a Project "FJ" - part #31
Here is the rest of it...
certifiablejeep.com - Project "Free Jeep" a.k.a Project "FJ" - part #34
Hope that helps a bit and gives you some ideas.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #3 of 5 Old 10-23-2009, 08:05 AM
certifiablejeep
Bicentennial Nickel
1976 CJ5
PS, I do have a YJ setup that has most of the parts that we took out of a YJ tub swap... if you could use it, PM me or email me at cbrown@certifiablejeep.com and we can talk.
Craig
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #4 of 5 Old 10-23-2009, 08:05 AM
Mike Romain
I have modified a couple YJ 258 heater boxes with the big GM blower motor and these ones looked the same as the CJ one so no real modifications were needed. oh, the switches were different, the YJ blower motor switch only has a low on it, no off, the off is on the vent control. Don't know that that matters if you use CJ controls.
That said I highly recommend the GM blower upgrade, it puts out more at low than the CJ one did on high.
Jeep Heater Blower Motor Upgrade
Mike
Mike Romain is offline
post #5 of 5 Old 10-23-2009, 08:10 AM
certifiablejeep
Bicentennial Nickel
1976 CJ5
Absolutely on the upgrade as well, however, the cables attaching to the outer part of the heater box and the side near the passenger door is much different, you could probably get them to work, but I never tried to do that. I just used the backing plate as those were the same... I also used the YJ blower motor as well as the YJ deflector on the bottom.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-12-2009 11:36 PM
Heater Hoses Minus The Heater KBONSIG Jeep CJ Forum 3 03-30-2008 07:36 AM
Heater Craft brand heater upgrade PhatBasturd Jeep CJ Forum 0 12-31-2007 08:50 AM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
