yj brake booster swap? - JeepForum.com
post #1 of 29 Old 02-03-2010, 04:53 PM Thread Starter
gotCLAY
Dose it matter if it is a 4cyl or 6cyl for the brake booster and master cylinder swap?
GOOD LUCK & GOD BLESS
gotCLAY is offline
post #2 of 29 Old 02-03-2010, 04:59 PM
Jeepican
1976 CJ5
Wouldn't think so..
1976 CJ5 - 232 I6, MC2100, YJ Booster, Front disc conv, 2.5" BDS, 1" Body Lift, .5" lift Daystar Shackles, 33 x 10.50 BF KM2, Twin Stick
"Oh, you're just full of fun today, aren't you? Why don't we go up to the old people's home and wax the steps?"
-Barney Fife-
Jeepican is offline
post #3 of 29 Old 02-04-2010, 01:42 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
You want the 1995 dual-diaphragm setup. Make sure you get the firewall bracket - that is the only part you can't go buy new at the store. I don't know if the motor makes a difference.
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #4 of 29 Old 02-04-2010, 02:14 PM
Jeepican
1976 CJ5
Motor should not matter as it isn't tied to the motor.... (besides vaccum lines) Someone correct me if I'm wrong..
-Barney Fife-
Jeepican is offline
post #5 of 29 Old 02-04-2010, 03:01 PM
jumbojeepman
1976 CJ7
Does the firewall bracket have to be from a 1995, or can you use any YJ bracket with a 1995 brake booster?
jumbojeepman is offline
post #6 of 29 Old 02-04-2010, 03:55 PM
scottymac62
1979 CJ7
Any year YJ firewall bracket will bolt up to a 95 booster. And that will bolt up to your CJ with no problem.
'77 CJ-5 Renegade 304 / T-150, Dana 20, 30/20 axles, Aussie Locker in the Dana 30, American Racing 15x10 Outlaw II's, 33" Dynapro M/T's" ,Optima Battery, TeamRushed + Summit Racing CDI ignition, FlowKooler water pump, Edelbrock Performer Intake Manifold, Holley 4160 390cfm, Herculiner, Silver Ceramic Coated Hedman Hedders, Flowmaster 40's.
Warn PowerPlant HD 12K Winch, Dirtworx front and rear bumpers.
scottymac62 is offline
post #7 of 29 Old 02-11-2010, 01:30 PM
mooncruiser
Will YJ booster interfere with support rod?
Will the brake booster hit the support rod that comes from the front bib/grill area to the firewall?
mooncruiser is offline
post #8 of 29 Old 02-11-2010, 02:20 PM
ElZorro
No, they are pretty compact boosters, not the big ones you might be used to seeing. Davey's Jeeps had one for sale a little while back with a good pic, but last time I looked it was gone. Do a search for 95 booster and you're bound to find a pic in one of the threads. You do have to worry about the air cleaner though, there was one for non-power breaks and the pacer style for power brake equipped jeeps that shifted the air cleaner more towards the center of the engine bay.
ElZorro is offline
post #9 of 29 Old 02-17-2010, 06:14 PM Thread Starter
gotCLAY
So Im not 100% on this but at three auto parts store the 4cyl and the 6cyl for a 95 have two different part numbers so I would think that there must be something different.
gotCLAY is offline
post #10 of 29 Old 02-17-2010, 06:32 PM
mooncruiser
I have a 77 CJ5 w/ manual brakes and 4wheel disc brakes. It stops fine but I can't lock them up if I had to- I have 35's. I just bought a 90' YJ MC/booster from a salvage yard and bolted it up yesterday. I know it is a single diaphragm but I'm sure power vs manual will be much better, single or dual. Don't get me wrong, I would have gone dual but couldn't find a 95 at the salvage yards.
It was a straight bolt-on, the 4 bolts were already in the firewall-they serve to support the plate on the inside of the firewall that holds the brake and clutch pedal assembly. It does not get in the way with the support rod or the clutch master cylinder (Novak conversion).
The rod fit perfect on the stud on the brake pedal, no need to use a bushing and, it is only about a 1/4" shorter than the original manual MC brake clevis/rod. I'm hoping I don't need to pull it out and cut,thread to adjust it out.
I run a wilwood (from Summit-about $38.00) adjustable proportioning valve in line for the rear brakes, the fronts go straight to the MC - I completely removed the stock proportioning valve long ago and have been using the wilwood valve-works great. I had the same set-up on my 72 FJ40 w/4 wheel disc and I wouldn't do it any other way.
post #11 of 29 Old 02-17-2010, 07:45 PM
chadcarter
1983 CJ7
I just want to add, that while the dual diaphragm booster does work better, I have the single diaphragm booster and can lock up 35s if I had to, and I have. The single booster is a large improvement over stock if that all you can find.
1983 Jeep CJ-7, AMC 360 swap, TF999, AMC 20 w/ 4.10s Mosers & Detroit, Dana 30 4.10s Open. 4" BDS with 1" Daystar BL & 1" Shackle lift. 35x12.50x15 General Grabber M/T. Corner & Rocker protection by Sniper Fab, with Bumpers by GroundPounder Fab.
chadcarter is offline
post #12 of 29 Old 02-17-2010, 08:06 PM
rixcj
rixcj's Avatar
1979 CJ5
I have a 1995 YJ Dual Diaphragm booster/ MC setup for sale, if anyone's interested...
I haven't listed this anywhere, but it seemed to be appropiate for this thread. If it doesn't belong here, mods, please feel free to move it.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #13 of 29 Old 02-17-2010, 08:23 PM
ElZorro
Rich
Interested, PM Sent.
ElZorro is offline
post #14 of 29 Old 02-17-2010, 09:56 PM
PavementPounder
Cool as Ice...
Napaonline.com shows 2 part numbers for 1995, but they also show pictures. There is a single and a dual. The single is probably the 4-cyl application.
post #15 of 29 Old 02-17-2010, 09:58 PM
GraKee99
Rapist Wit
GraKee99's Avatar
YJ Brake Booster Upgrade
Brian
WJ, WK, CJ5
GraKee99 is offline
cherokee brake booster to cj5 swap? 1Rustycj5 Jeep CJ Forum 6 07-23-2009 03:44 AM
yj/cj brake booster swap tsujeeper Jeep CJ Forum 7 05-14-2007 07:18 AM
Power brake booster and master cyl. swap question ademster Jeep CJ Forum 2 10-14-2006 06:58 PM
yj brake booster on a manual drum brake cj5? 77 renegade Jeep CJ Forum 2 02-12-2005 06:17 PM
Yj Brake Booster swap jamesa Jeep CJ Forum 6 10-27-2004 05:06 PM
