Quantcast YJ Brake Booster fit a CJ with OE PB? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > YJ Brake Booster fit a CJ with OE PB?
Old 03-25-2007, 01:46 PM   #1
Joey_B
Does anyone know if a YJ brake booster will fit in to replace an 85 CJ brake booster? I'm not changing the MC, just the booster.
Thanks.
Joey
Joey_B is offline   Reply With Quote
Old 03-25-2007, 02:53 PM   #2
only in a jeep cj
CJ OWNER FOR LIFE
From the research I've done, it will work if you do two things, Oval out the CJ master mounting holes slightly outward to fit the YJ booster and shorten the YJ booster to master pushrod to fit the CJ master (as its shorter) it must be exact.
I went with the YJ booster/master/ and pedals, but have to bend/make new lines from the master to the Porp valve.
Ed
1975 CJ-6 304 T15 Dana20 30/44 3.73
1983 CJ-8 258 T5 300 30/44 3.31 Looking for full or half hardtop buy or trade
1986 CJ-7 Laredo 4.6 stroker T5 300 30/44 3.31
1986 TJ-7 Trail Jeep project in the works
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline   Reply With Quote
Old 03-25-2007, 05:40 PM   #3
Joey_B
Thanks, I was hoping it was a straight bolt on job. I did a search before posting and found you had to shorten the pushrod for a manual to PB conversion but wasn't sure about a PB to PB one. Thanks again.
Joey
Old 03-26-2007, 07:21 AM   #4
GPER
1979 CJ7
I found that out awhile back so I'm just going with the yj mc and booster. I think there is too much to chance messing with the rod coming out of the booster.
GPER is offline   Reply With Quote
Old 03-26-2007, 06:17 PM   #5
jatepper
jatepper's Avatar
Before you go to the YJ mc, do you have a 258? I did the swap and I have a minor clearance problem. The air filter housing is a hair too big so I took a mallet and banged on it a little. Now it barely fits, and the cover barely closes on it. In fact, the cover dosent close on it at all.
Take this in consideration. Let me know if you have any problems or need any advice
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Torchmate CNC Plasma Table Build / Projects
Handen Fabrication
jatepper is offline   Reply With Quote
Glock Forum
