yj 2.5 in cj frame - JeepForum.com
post #1 of 3 Old 01-10-2010, 06:34 AM Thread Starter
luv2jeep
yj 2.5 in cj frame
I have a running 2.5 drivetrain out of a 92 and a 79 cj7 frame how can i mount the motor to the motor mounts anybody have a clue?
luv2jeep is offline
post #2 of 3 Old 01-10-2010, 10:42 AM
only in a jeep cj
So I guess another question would be does the YJ 2.5 block mounts interchange with either of the AMC/GM 4 cyls used in the CJ. (like the 4.2 and 4.0 does) I think the GM 4cyl went into a 7 in 1980, so your 79 would need later CJ 4 cyl mounts IF it did swap.
I would only do this swap if the CJ was a 4cyl and I wanted to keep it and gain the later YJ 4 cyl for its fuel injection.
I guess you know about the t-case offset and the axles not going to fit...
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #3 of 3 Old 01-10-2010, 11:00 AM Thread Starter
luv2jeep
yeah just need to mount the engine
luv2jeep is offline
back half of cj5 frame to replace rotted cj7 frame? jedsled Jeep CJ Forum 8 05-30-2011 05:11 AM
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 08:44 PM
Stock Frame Vs. Mandrel Bent Frame HeepToJeep Jeep CJ Forum 8 05-10-2009 06:28 AM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 10:44 PM
Rear shackle to frame bolts, how do you get in the frame? Blthomas Jeep CJ Forum 5 02-19-2009 07:26 PM
