YF carter carb on 53 m38a1 won't accelerate - JeepForum.com
post #1 of 11 Old 08-11-2009, 02:31 PM Thread Starter
gamebirder
1953 M-38
I just went through and rebuilt this carb because of overloading issues. There were not a lot of part involved in the kit so it was mainly a clean up and place new gaskets. After reinstalling it would idle fine but as I push the accelorator it would start to die and if I tried to keep it running by pumping the gas it would start backfiring. I have had it back apart twice double checking the float adjustment and metering rod adjustment but still cannot get to run. Any suggestions or would I be better off to just replace with a solex or something similiar. thanks
gamebirder is offline
post #2 of 11 Old 08-11-2009, 04:20 PM
John Strenk
John Strenk's Avatar
1976 CJ5
Sounds like problem with the accelerator pump. Does it squirt when you hit the accelerator? Take off the air cleaner and pump the throttle a few times and see if you can see any gas squirting down the carb.
Did you get all the check balls back in?
John Strenk is offline
post #3 of 11 Old 08-12-2009, 09:43 AM Thread Starter
gamebirder
1953 M-38
I don't really get a squirt just a few bubbles and a little gas along the edge.
post #4 of 11 Old 08-12-2009, 10:10 AM
John Strenk
1976 CJ5
Nope not good.
Mine is a good solid stream.
Did you get the accellerator pump oriented properly?
post #5 of 11 Old 08-12-2009, 06:53 PM Thread Starter
gamebirder
1953 M-38
Thanks for the picture. I think mine is a little different I don't have it in front of me but I don't recall the inlet ball check and the discharge check ball and weight was one piece that had a point in the direction of the ball, also I don't believe the pump jet protrudes into the barrel at all. The actual number on the carb is yf 938s. thanks again.
post #6 of 11 Old 08-13-2009, 04:37 AM
John Strenk
1976 CJ5
One of these huh:
Notice the part on the accelerator pump at the top of this page.
Does this look familiar? I found it with a bunch of other YF drawings. This is more of a mechanical schematic than the actual layout.
The old YF and New YF are so close, some of the same gaskets are similarly shaped after 30 years.
Actually there is a great writeup at the CJ3BSite.com site.
http://www.film.queensu.ca/CJ3b/Tech/Carburetor.html
http://www.film.queensu.ca/CJ3b/Tech/Carter.html
Here is another site with some info.
http://www.oldcarmanualproject.com/m...r/YF/index.htm
Still you should get a strong flow of gas coming out of the port for the accelerator pump. Make sure all your gaskets were installed correctly, you could inadvertently block off a hole, and all passages are clear.
post #7 of 11 Old 08-13-2009, 05:11 AM
John Strenk
1976 CJ5
These are good technical notes:
post #8 of 11 Old 08-13-2009, 10:10 AM Thread Starter
gamebirder
1953 M-38
yep this is the one. thanks for all the good info. I will go over this and double check everything when I remove the carb again this weekend.
post #9 of 11 Old 08-13-2009, 10:30 AM Thread Starter
gamebirder
1953 M-38
do you have any idea if a person can still get that discharge ball kit from carter #116-27u. this did not come in my rebuild kit and i think this may be one of the problems. like i said this one does not have a ball but more of a pointed weight. The kit came with some little balls but I never saw any in the carb.
post #10 of 11 Old 08-13-2009, 10:56 AM
John Strenk
1976 CJ5
Depends upon the kit. Sometimes the pointed weight can be swapped with a couple balls. I think the smaller one drops in first.
http://www.jeepforum.com/forum/f8/carter-yf-rebuild-question-715326/
post #11 of 11 Old 01-17-2010, 07:27 PM
bprimrose
1978 CJ5
1978 cj5 258 carter YF when rebuild had no discharge ball/weight?
Hello,
I have a question RE Carter YF CArb. I rebuilt and found no discharge ball or weight in place. SO....I just put it back together. NOw I have a problem with stall and running until it is fully warmed up? I wold appreciate any help. SHould I replace the weight and Ball?
Thanks
bprimrose is offline
'72 CJ5 - 232 w/ Carter YF Carb 1972-CJ5 Jeep CJ Forum 2 11-23-2009 07:44 AM
Carter Carb Help----Carb Guru's Goody1231979 Jeep CJ Forum 4 04-28-2009 06:03 PM
Carter AFB carb issue (general carb) danheit Jeep CJ Forum 1 04-19-2009 05:34 PM
carter carb DonAltman3 Jeep CJ Forum 4 04-28-2008 07:34 PM
Carter YF Carb solitudetree Jeep CJ Forum 4 07-05-2007 05:13 AM
