The "yet to be named" 1978 CJ7 build. - Page 6 - JeepForum.com
 3Likes
post #76 of 112 Old 05-23-2013, 04:57 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Thanks, brother. Found a guy south of San Antonio selling a used fiberglass body for $750... Come to find out its a CJ5 and not a CJ7. I have a hard time fitting on a 5, otherwise I'd be all over that.
Now that the rear end is done, I'm going to do a drum brake job, then start working my way forward, new seals on transfer case, transmission and oil pan. Once I get to the front I will pull off the front and and start replacing steering parts.
Question for the masses. Is it worth the money to replace the gas tank or just use the one I pulled off?
-Dave
AustinCJer is offline
post #77 of 112 Old 06-16-2013, 06:48 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Picked up this 84 CJ7 today to complete my 78. Tub is almost rust free, dash components are in great shape and it has a few extras here and there that I could use. I'll sell what I don't use and should make my money back no problem.
-Dave
post #78 of 112 Old 06-19-2013, 10:53 AM
AustinTexasXJ
1987 MJ Comanche
damn not bad! good find man!
Benjamin
ΜΟΛΩΝ ΛΑΒΕ!
AustinTexasXJ is offline
post #79 of 112 Old 06-20-2013, 09:24 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
So if I have the body of an 84 CJ7 and the frame/engine of a 78 CJ7, what year do I tell people it is.
-Dave
post #80 of 112 Old 06-20-2013, 11:49 AM
CjHouch
CjHouch's Avatar
1976 CJ5
You could always use the vin plate off the 78 on the 84 body and sell the vin and title for the 84 for a couple hundred dollars. Then you'd have matching frame and body numbers on your 78 CJ7 and a couple hundred bucks for more parts.
Greg
CjHouch is offline
post #81 of 112 Old 06-20-2013, 12:49 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
So put the 84 vin on the 78 body and sell it like that? The 78 body is pretty mangled.
-Dave
post #82 of 112 Old 06-20-2013, 01:22 PM
CjHouch
CjHouch's Avatar
1976 CJ5
You can just part out the 84 piece by piece. I've seen people sell the vin plate and title by them selves. Works good for someone with a frame and no title and using a fiberglass body or someone building with aftermarket frame and body. Somebody could use it and its worth the money to them.
Greg
CjHouch is offline
post #83 of 112 Old 06-20-2013, 01:34 PM
CjHouch
CjHouch's Avatar
1976 CJ5
Guess what I'm trying to say is you don't want to mislead or misrepresent by putting the 84 vin on the 78 body. The vin and title have value all there own.
Greg
CjHouch is offline
post #84 of 112 Old 06-20-2013, 02:04 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Ah, I didn't realize the vin plate and title would work like that, but it makes sense. Thank you for the advice.
-Dave
post #85 of 112 Old 06-26-2013, 08:57 AM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
So much happening right now. I selling a lot of the parts from the 84 I bought to clear out my garage.
I'll finish painting the frame this week and then work on the front axle and steering.
In the next month I hope to clean up the new body, patch a couple small holes, and bed line the inside and undercarriage.
Once that's done, I'll get the exhaust back on, run new brake lines, and then I should be ready for the body.
Finding this donor was the best approach to getting this thing on the road sooner rather than later.
I'll keep y'all posted.
-Dave
post #86 of 112 Old 10-28-2013, 02:55 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
So its been a week shy of a year ive had the CJ in my possession...
And I FINALLY got the money rounded up to order brake lines, body mounts, tranny sway bushings, shocks, and tires.
Now that all these parts are on their way, I can get some work done.
Seal the undercarriage of the donor tub with bedliner and covered the shifter hole with a shifter plate I found online (body was a manual, my jeep is automatic).
Im hoping to get the rear brakes, exhaust and gas tank put together by next week and I can finally put the body back on.
Went with 35" BFG M/T, 1" daystar lift, and daystar bushings.
-Dave
post #87 of 112 Old 11-15-2013, 12:22 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Hey guys and gals.
Got to talking about my SOA lift that was installed before I bought the Jeep. I DO NOT plan on doing any offroading with this Jeep; its going to be a street queen
With that being said, is a traction bar going to be necessary? Can I get away without one if Im just running around town and taking the Jeep on road trips to the beach?
I am making some ground that im pretty happy about. Bent brake lines myself for the rear drum brakes, new rubber, new gas tank and sending unit, got the undercarriage of the body sanded down and ready to be sealed and coated. Once I get the gas tank back on and the exhaust reinstalled, ill be able to get the body back on... And its only taken 1 year. LOL.
http://www.jeepforum.com/forum/attac...1&d=1384543316
1425772_10100126228494502_1420430773_n.jpg   1467185_10100127759371612_1724204903_n.jpg
-Dave
post #88 of 112 Old 01-11-2014, 11:54 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
So after so discussion and thought, I've made a handful of decisions with the Jeep. I've patched all the holes with fiberglass and bondo and sealed the entire underside with bedcoating.
I'm pretty close to being able to putting the body back on, then I can tweak the engine.
I'm drunk... But pretty excited to get to it tomorrow.
-Dave
post #89 of 112 Old 01-19-2014, 11:46 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
Dash is ready
Everything from the engine back is done
Next:
Body on and out of the way
Spin the jeep around
Work on the from axle, brakes, and steering components.
-Dave
post #90 of 112 Old 01-21-2014, 07:48 PM Thread Starter
AustinCJer
u mad, bro?
AustinCJer's Avatar
1978 CJ7
81 inches to the top of the roll bar. God damn monster!
-Dave
