Yet another problem with the CJ - JeepForum.com
post #1 of 2 Old 08-19-2003, 02:28 PM Thread Starter
sullju
I'm trying to figure out why my friends Jeep is backfiring and running rough over 40m.p.h. The mechanic he took it to said that it was an electrical issue, but it is running rich. Could this be a problem with the fuel mixture or is the wiring problem causing it to missfire and then in turn flooding it. Thanks for all the help.
sullju is offline
post #2 of 2 Old 08-19-2003, 02:44 PM
Lightningdon
Lightningdon's Avatar
The first thing I look at when the engine breaks down at higher rpms, is the coil. I have had more than 1 fail. First sign was roughness as the rpms come up. Sometimes can not run over 3000 rpm. Could also be an issue with the points and condensor if so equipped. Check the wiring between ignition box, coil, and distributer.
'97 TJ
'75 CJ5 304cid, t18 tranny w/granny low, model 20 T Case, DANA 44 rear, 30 front, 4" suspension lift, 33" tires, in need of more work!
"The only thing necessary for the triumph of evil, is for good men to do nothing." (Edmund Burke)
Lightningdon is offline
CJ7 amc 20 problem! HELP!! sbcranger Jeep CJ Forum 11 03-25-2009 10:10 PM
What could be the problem now? Jeepguy91 Jeep CJ Forum 11 03-15-2009 08:17 AM
New guy, old problem. mjolman Jeep CJ Forum 4 03-31-2008 12:15 PM
TBI problem j.creepers Jeep CJ Forum 7 10-26-2006 05:43 AM
Big cj7 problem jeepin cj-5 Jeep CJ Forum 4 10-04-2003 07:34 PM
